Teraz jest 22 lis 2026, o 18:05
PostNapisane: 30 lis 2019, o 13:57
Dołączył(a): 30 lis 2019
MyFile.c: 1: 57: fatal error: p30f6014.h: No such file or directory
PostNapisane: 30 lis 2019, o 15:30
We are not diviners, you need to include your source code (use correct syntax).
PostNapisane: 30 lis 2019, o 16:43
Dołączył(a): 05 wrz 2017
Instead of:
You should use
File xc.h internally finds right header file for your controller and safe you from attach wrong file or attach it wrong like in your error message. Of course if you use xc16 compiller.
