KURS HOME ASSISTANT
    Teraz jest 2 cze 2025, o 12:34
    PostNapisane: 20 sie 2019, o 21:47
    Dołączył(a): 09 lip 2019
    Krótka i na temat ściąga techniki analogowej od Texas Instruments... i trochę cyfrowej. Pewnie przyda się nie tylko początkującym. Dostępna na stronie:
    http://www.ti.com/amplifier-circuit/op-amps/precision/support-training.html#pocketref
    W szczególności
    https://www.ti.com/seclit/ml/slyw038c/slyw038c.pdf
    Dostępne też w formie apek na iOS i Android
    Spis treści
    Conversions
    Physical constants / Standard decimal prefixes
    Metric conversions
    Temperature conversions
    Error conversions (ppm and percentage)
    Discrete components
    Resistor color code
    Standard resistor values
    Practical capacitor model and specifications
    Practical capacitors vs frequency
    Capacitor type overview
    Standard capacitance values / Capacitance marking and tolerance
    Diodes and LEDs
    Bipolar junction transistors (BJT)
    Junction field effect transistors (JET)
    Metal oxide semiconductor field effect transistor (MOSFET)
    Analog
    Resistor equations / Ohm’s law and voltage divider equation
    Power equations
    Capacitor equations
    Inductor equations
    Equation for charging an RC circuit
    Equation for discharging an RC circuit
    Capacitor with constant current source
    RMS and mean voltage
    Logarithmic mathematical definitions / Alternative notations
    dB definitions
    Log scale
    Time to phase shift
    Bode plots: Poles
    Pole (equations)
    Bode plots (zeros)
    Zero (equations)
    Amplifier
    Basic op amp configurations
    Simple non-inverting amp with Cf filter
    Simple inverting amp with Cf filter
    Differential filter cutoff
    Calculating amplifier offset voltage
    Op amp bandwidth
    Small signal step response
    Full power bandwidth
    Large signal response (slew rate)
    Settling time
    Combining noise sources / Averaging noise sources
    Noise bandwidth calculation
    1/f total noise calculation
    Thermal noise calculations
    Op amp noise model
    Total noise calculations
    AC response versus frequency (dominant 2-pole system)
    Transient overshoot (dominant 2-pole system)
    Stability open loop SPICE analysis
    Stability transient square wave lab test
    Stability AC sine wave lab test
    Power dissipation calculation
    Electrical overstress (EOS) protection
    PCB and wire
    PCB printed circuit board conductor spacing
    Self-heating of PCB conductors on inner layers
    PCB trace resistance
    PCB trace resistance for 1 oz-Cu
    PCB trace resistance for 2 oz-Cu
    Common package types and dimensions
    PCB parallel plate capacitance
    PCB microstrip capacitance and inductance
    6 Texas Instruments Analog Engineer's Pocket Reference
    PCB and wire (cont.)
    PCB adjacent copper traces
    PCB via capacitance and inductance
    Coaxial cable information
    Coaxial cable equations
    Resistance per length for different wire types (AWG)
    Maximum current for wire types
    Sensor
    Temperature sensor overview
    IC temperature sensor overview
    RTD equation temperature to resistance (T>=0C and T<0C)
    RTD equation resistance to temperature (T<0C or Rrtd<R0)
    Diode equation vs temperature
    Diode voltage versus temperature
    Type J thermocouples translating temperature to voltage (ITS-90 standard)
    Type J thermocouples translating voltage to temperature (ITS-90 standard)
    Type K thermocouples translating temperature to voltage (ITS-90 standard)
    Type K thermocouples translating voltage to temperature (ITS-90 standard)
    Thermistor: Resistance to temperature, Steinhart-Hart equation
    Digital
    Numbering systems: binary, decimal and hexadecimal
    Data formats
    Digital logic thresholds
    CMOS logic thresholds
    SPI (Serial peripheral interface) hardware overview
    SPI data latching
    SPI critical edge
    SPI modes
    I2C bus (Inter-integrated circuit) hardware overview
    I2C addressing
    I2C communication
    I2C setup, hold and rising timing
    I2C pull-up resistor selection
    ADC
    ADC definitions
    ADC resolution for unipolar
    ADC resolution for bipolar
    Resolution voltage vs. full-scale range
    Quantization error of ADC
    Signal-to-noise ratio (SNR) from quantization noise only
    Total harmonic distortion (VRMS)
    Total harmonic distortion (dBc)
    Ac signals
    Dc signals
    Settling time and conversion accuracy
    ADC system noise calculation
    Effect of clock jitter on ADC SNR
    DAC
    DAC definitionas
    DAC errors
    DAC non-linearity
    DAC total unadjusted error
    Multiplexer
    CMOS switch construction
    ON-resistance (RON)
    RON flatness / Effective op amp gain including MUX RON
    ON and OFF capacitance (CON/COFF)
    MUX settling time with CLOAD and RLOAD
    Leakage current
    Charge injection
    Bandwidth (BW)
    Channel-to-channel crosstalk(XTALK)
    OFF-isolation
    Total harmonic distortion plus noise
    PostNapisane: 20 sie 2019, o 22:45
    moscow napisał(a):
    no to jest dopiero PEREŁKA !!!! i mega extra PODSUMOWANIE ;) coś Qurdę przepięknego !
    PostNapisane: 21 sie 2019, o 10:12
    Dołączył(a): 12 maja 2014
    O kuźwa :shock:
    DIAMENT ;)
    DZIEKI moscow 8-)
    Yes We CAN ;)
    PostNapisane: 21 sie 2019, o 10:15
    To już piąta edycja. Miałem poprzednią. Tą też ściągnąłem ;)
    PostNapisane: 21 sie 2019, o 15:57
    Dołączył(a): 31 sty 2014
    Ja właśnie niedawno odkryłem, jakie Texas Instruments robi dobre dokumentacje. Jestem w trakcie projektowania sterownika do silnika BLDC i postanowiłem skorzystać z ich smart gate drivera. Datasheet scalaka porządny, prawie jak nota jakiegoś mikrokontrolera :D Do tego dodatkowo szereg PDFów opisujących ideę działania układu z całym wstępem teoretycznym, albo obszerny opis jak należy optymalnie zaprojektować PCB (EMC itp). A także przykładowa aplikacja ze schematem, projektem PCB, obliczeniami i przebiegami z oscyloskopu.
    Naprawdę jestem pod wrażeniem, ich dokumentacje czyta się jak dobrą książkę, trzeba uważać bo wciąga ;)
