Teraz jest 18 sie 2026, o 19:09
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 70 ]  Przejdź na stronę Poprzednia strona  1, 2, 3  Następna strona
PostNapisane: 19 lip 2015, o 11:16
Dołączył(a): 19 gru 2012
U mnie niestety taki oto efekt skopiowania plików wygenerowanych przez program do eclipsa.
make all
Building file: ../LCD/lcd44780.c
Invoking: AVR Compiler
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega32 -DF_CPU=14745600UL -MMD -MP -MF"LCD/lcd44780.d" -MT"LCD/lcd44780.d" -c -o "LCD/lcd44780.o" "../LCD/lcd44780.c"
Finished building: ../LCD/lcd44780.c
Building file: ../jbmenu.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega32 -DF_CPU=14745600UL -MMD -MP -MF"jbmenu.d" -MT"jbmenu.d" -c -o "jbmenu.o" "../jbmenu.c"
../jbmenu.c: In function 'display_menu':
../jbmenu.c:60:8: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
In file included from ../jbmenu.c:13:0:
../LCD/lcd44780.h:172:6: note: expected 'const char *' but argument is of type 'const unsigned char *'
../jbmenu.c:62:8: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
../jbmenu.c:68:8: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
../jbmenu.c:71:8: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
../jbmenu.c:77:8: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
../jbmenu.c:80:8: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
../jbmenu.c: In function 'zmiana_wartosci':
../jbmenu.c:184:3: warning: pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign]
Finished building: ../jbmenu.c
Building file: ../jbnapisy_flash.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega32 -DF_CPU=14745600UL -MMD -MP -MF"jbnapisy_flash.d" -MT"jbnapisy_flash.d" -c -o "jbnapisy_flash.o" "../jbnapisy_flash.c"
Finished building: ../jbnapisy_flash.c
Building file: ../main.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega32 -DF_CPU=14745600UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c"
../main.c:29:8: warning: passing argument 2 of 'lcd_defchar_P' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ../main.c:15:0:
../LCD/lcd44780.h:177:6: note: expected 'unsigned char *' but argument is of type 'const unsigned char *'
../main.c:30:8: warning: passing argument 2 of 'lcd_defchar_P' discards 'const' qualifier from pointer target type [enabled by default]
../main.c:31:8: warning: passing argument 2 of 'lcd_defchar_P' discards 'const' qualifier from pointer target type [enabled by default]
Finished building: ../main.c
Building target: menu_test.elf
Invoking: AVR C Linker
avr-gcc -Wl,-Map,menu_test.map -mmcu=atmega32 -o "menu_test.elf"  ./LCD/lcd44780.o  ./jbmenu.o ./jbnapisy_flash.o ./main.o
./jbmenu.o: In function `zmiana_wartosci':
jbmenu.c:(.text+0x2d6): undefined reference to `copy_ram_eeprom'
./jbmenu.o: In function `on_off':
jbmenu.c:(.text+0x368): undefined reference to `copy_ram_eeprom'
collect2.exe: error: ld returned 1 exit status
make: *** [menu_test.elf] Błąd 1
Pliki skopiowane bezpośrednio z wygenerowanego folderu + dodana biblioteka LCD Mirka
PostNapisane: 19 lip 2015, o 15:25
Dołączył(a): 04 kwi 2014
Update w 1 poście. Na samym dole należy zapoznać się ze zmianami.
Mam nadzieję, że będzie teraz działać. W razie czego proszę o informację.
PostNapisane: 21 lip 2015, o 19:49
Dołączył(a): 17 sty 2013
Bardzo fajny program! Dziękuję, że kolega się z nami podzielił ;)
PostNapisane: 22 lip 2015, o 08:08
Ciesze się :) Czyli rozumiem, że działa wszystko, a generowany kod kompiluje się bez warningów i errorów ?
PostNapisane: 22 lip 2015, o 14:14
Na chwilę obecną nie potrzebuję tworzyć menu jako takiego. Swojego czasu skrobałem menu które ma 4 poziomy i 71 elementów do wyboru. Teraz jak będę robił podobny projekt (a planuję to zrobić) to na 100% wykorzystam możliwości Twojego dzieła i zdam relację jak działa.
PostNapisane: 22 lip 2015, o 20:50
PANOWIE! Przepraszam, nie wiem jak to się stało, ale w wersji v1.3 w funkcji change_menu pojawił się błąd, który przy zapisywaniu struktury menu do pamięci FLASH powoduje złe odczytywanie, dokładnie chodzi o linie:
a powinno być:
w 1 pości podmieniona wersja 1.3 :)
PostNapisane: 23 lip 2015, o 13:23
Dołączył(a): 07 maja 2014
Stworzyłem nieduże menu za pomocą programu dodałem obsługe klawiszy w main.c w pętli while za pomocą mirkowego superdebounce w ten sposób
 int main(void)
   uint8_t k1,k2,k3,k4;
   DDRA |= (1<<PA2);   // wyjście diody LED
   DDRC |= (1<<PC6);
   PORTC |= (1<<PC6); // podswietlenie wyswietlacza chwilowo na stale
   lcd_init(); // inicjacja LCD
   lcd_cls(); // wyczyszczenie ekranu lcd
   lcd_defchar_P(0x80, znak_strzalka); // definicja znaku LCD w pamieci
   lcd_defchar_P(0x81, znak_termo); // definicja znaku LCD w pamieci
   lcd_defchar_P(0x82, strzalka_dol); // definicja znaku LCD w pamieci
   lcd_locate(0,0);   lcd_str("TEST MENU");
   PORTD |= KL1|KL2|KL3|KL4;   /* Timer2 – inicjalizacja przerwania co 10ms */
   TCCR2 |= (1 << WGM21);         // tryb pracy CTC
   TCCR2 |= (1 << CS22) | (1 << CS20);   // preskaler = 1024
   OCR2 = 155;            // przerwanie porĂłwnania co 10ms (100Hz)
   TIMSK |= (1 << OCIE2);         // Odblokowanie przerwania CompareMatch
   sei(); // globalne wlaczenie przerwan
   while(1){
       SuperDebounce(&k1, &PIND, KL1, 20, 1000, OK, OK);
       SuperDebounce(&k2, &PIND, KL2, 20, 1000, UP, UP);
          SuperDebounce(&k3, &PIND, KL3, 20, 1000, DOWN, DOWN);
          SuperDebounce(&k4, &PIND, KL4, 20, 1000, PREV, PREV);
      MENU_EVENT();
      if(!Timer3){
         Timer3=100;
         PORTA ^= (1<<PA2);
na wyświetlaczu otrzymuje tylko to co ma wyświetlić funkcja " screen_main "
lecz jak nacisne którykolwiek z przycisków i puszcze na pierwszym miejscu wyswietlacza przez ułamek sekundy można dostrzec znak -> czyli reakcja klawisze jest.Przerwania są generowane poprawnie gdyż diodka podpięta do PA2 mruga sobie co sekunde.
Nie wiem czy coś ja skopałem z obsługą klawiszy superdebounce czy generator menu tworzy błędnie kod.
Może autor zerknie na moje wypociny i coś podpowie w temacie:)
PostNapisane: 23 lip 2015, o 13:32
W funkcji change_menu masz na pewno:
edit:
@usiex daj znać, bo nie wiem czy szukać gdzieś dalej :)
PostNapisane: 23 lip 2015, o 14:02
Widzisz co głowa to głowa .Wczytałem do ostaniej wersji programu włąśnie z tą poprawką wersje wygenerowaną z poprzedniej wersji i dałem generuj kod lecz jednak niezmieniło.Teraz mogę wejść do menu i przemieszczać się po nim.Denerwują ce jest jednak to że będąc w ekranie glównym naciskają klawisz up down lub prev ekran mruga przy puszczeniu oraz wkurzający jest ten kwadracik który się naklada gdy zmienia się wartość którą chcemy ustawić .Również trzeba by było ograniczyć ilość znaków z napisami menu gdyż je obcina a to z tego względu że pozycji aktywnego menu wyskakują na początku dwa znaki(wyświetlacz 2x16).Dużym problemem byłoby aby np temperatura zadawana była np co 0.5 C. Czy w polu jednostki można wstawić jakiś zdefiniowany znak np stopień celcjusza ? i jeszcze jedno czy parametry początkowe po zaprogramowaniu procesora powinny wynosić 0 czy powinny mieć wartośći ustalane początkowo w strukturze?.Jeżeli kolega bloniak91 chce to mogę pisać o jeszcze innych problemach jak znajdę no chyba że masz już dość ;) .Proszę tylko o sugestie to coś spróbuje pokombinować w sprawach o których pisałem.
Ostatnio edytowano 23 lip 2015, o 14:17 przez usiex, łącznie edytowano 1 raz
PostNapisane: 23 lip 2015, o 14:16
Oczywiście poprawię.
To migający kursor? W funkcji zmiana_warosci i on_off wywal po prostu:
Są niby ograniczone. Jest tak, że liczba kolumn wyświetlacza-1. Dwa znaki? Muszę sprawdzić, jak wrócę do mieszkania.
usiex napisał(a):
Dużym problemem byłoby aby np temperatura zadawana była np co 0.5 C. Czy w polu jednostki można wstawić jakiś zdefiniowany znak np stopień celcjusza ?Proszę tylko o sugestie to coś spróbuje pokombinować
No tak, funkcje, które są w generatorze nie umożliwiają takiej opcji. Rozwiązań jest tyle co programistów np. 2 zmienne do jednej wartości- jedna przechowuje całości, druga ułamki. Kombinuj ;)
Dzięki za uwagi, pozdrawiam
PostNapisane: 23 lip 2015, o 14:25
Co odnosnie parametrow poczatkowych tez dodalem pytanie w poprzednim poscie?
PostNapisane: 23 lip 2015, o 14:53
Nie ma takiej możliwości. Po wygenerowaniu kodu możesz sobie w funkcji dla wybranego podmenu podmienić string na swój zadeklarowany znak.
Albo... wpisać do pola Jednostka już bezpośrednio kod znaku( między innymi tak jest wyświetlany znak strzałki).
Trzeba załadować ustawienia fabryczne żeby były początkowe, zadeklarowane w strukturze. Odsyłam do poradnika Mirka na temat struktur. Funkcje z resztą są wzięte z tego otóż wspaniałego poradniczka. Czyli tam funkcja sprawdz i zaladuj ustawienia fabryczne do maina.
PostNapisane: 23 lip 2015, o 16:29
Pobrałem zamieszczoną w 1 poście wersję v1.3 i funkcja change_menu jest poprawna, być może na dysku Ci się pomieszało. Dobrze ktoś wyżej wspomniał żeby dodawać w nazwie numer wersji...
Sprawdziłem, u mnie działa dobrze- maksymalna liczba znaków jest pomniejszona o 1 czyli na znak strzałki. Na początku wyskakuje jeden znak- znak strzałki. @usiex możesz mi ewentualnie podesłać na pw kod, sprawdzę co może być nie tak, bo wróżyć z fusów niestety nie umiem.
No i niestety (albo stety 8-) ) trzeba program rozszerzyć o dodatkowe funkcje- zrobić coś z tymi jednostkami co wiąże się z deklarowaniem znaków. Dorobię też obsługę polskich znaków.
Program miał pomóc mi w wielkim projekcie, a wyszło tak, że powstanie z tego wielki kombajn.
Pozdrawiam i czekam na dalsze sugestie, informacje o błędach itd.
PostNapisane: 23 lip 2015, o 17:23
Znalazlem bład z tym znakiem
w funkcji display menu jest taki dziwny znak
lcd_str("€");//znak strzalki
a powinien byc
lcd_str("\x80");//znak strzalki
Tak mi wygenerowało i w twoim przykładzie też jest taki dziwny znak.
PostNapisane: 25 lip 2015, o 19:25
Dołączył(a): 09 mar 2013
Pomysł na projekt jest po prostu super :)
Jeżeli będę miał jakiś większy projekt z menu do roboty to na pewno będę testował twoje dzieło drogi autorze tematu
Będziemy kibicować w rozwijaniu projektu :)
PostNapisane: 29 lip 2015, o 12:57
Kolejna uwaga.Program po wczytaniu jakiegoś projektu i dokonaniu w nim zmiana (zmiana nazwy w głównym menu) wyrzuca błąd w załączniku dodałem print screan.
PostNapisane: 11 wrz 2015, o 20:06
Dołączył(a): 08 kwi 2015
ja zadam lamerskie pytanie ,czy jest mozliwosc stworzonego menu za pomoca tego programu wrzucic je do arduino leonardo?
PostNapisane: 9 sty 2016, o 20:55
Dołączył(a): 02 kwi 2015
Witam!
Dziękuję za program. Przykład skompilował się poprawnie. Na ekranie LCD są dwie pozycje: KONTROLA TEMP i KONTROLA ALL (trochę inaczej niż w programie na PC po wczytaniu przykładu). W którym miejscu konfigurujemy piny klawiszy do obsługi menu.
PostNapisane: 12 sty 2016, o 18:22
Dołączył(a): 12 sty 2014
avrfun napisał(a):
Witam!
Piny klawiszy są skonfigurowane w main.c
A obsługę klawiszy można zrobić np. tak
main.c
PostNapisane: 12 sty 2016, o 18:48
Bardzo dziękuję.
Napisz proszę czy dobrze rozumiem filozofię działania tego menu. Jest sobie zegar. Zdarzenie MENU_EVENT() wywoływane "non-stop" w pętli while(1) czuwa aby menu było dostępne (co ono tak właściwie robi?) w każdym momencie. Wciskam KL "ok" i na LCD pojawia się struktura menu. Nawiguję ("up", "down") do "USTAW GODZINĘ" i wciskam "ok" co powoduje wywołanie funkcji callback związanej z tą pozycją menu (np. przestawienie zegara w tryb setup - mruga godzina). Funkcje te trzeba sobie uprzednio zdefiniować projektując menu. Może jest całkiem inaczej?
PostNapisane: 12 sty 2016, o 19:32
Aż tak mocny nie jestem w tym temacie , więc nie będę próbował wyjaśnić jak to jest do końca.
Sam nad tym siedzę i próbuję zrozumieć jak te wszystkie funkcje działają.
Może skieruję prośbę do kolegi Jakuba w imieniu własny i innych forumowiczów uczących się języka C o opisy funkcji :
void change_menu ( void )
void call_event_callback_fun(void)
Program do generowania menu rewelacja.
PostNapisane: 16 sty 2016, o 14:10
Po raz kolejny podchodzę do generatora menu. Przykład zamieszony przez Autora działa dobrze. Problem pojawia się w chwili gdy chcę za pomocą menu wywołać własną funkcję np. pozycja menu - temperatura3 + wciśnięcie OK -> wywołanie funkcji LED_TOG() (gdzie ją definiować) lub do zmienianej wartości nastawy w pozycji menu -temperatura1 przypisać konkretną zmienną ze swojego programu. Jak wywołać MENU_EVENT() w razie potrzeby (np. wejście w setup zegara), czy wystarczy "wyłączyć" wyświetlanie ekranu startowego? Bardzo proszę o pomoc bo program bardzo dobry i potrzebny, a Autor jakby zapadł się pod Forum ;)
PostNapisane: 16 sty 2016, o 21:53
Witam!
Zmieniam ustawienia nastawy temperatury w menu z przykładu np. na 60 stopni i przypisuję pole odpowiedniej struktury do zmiennej (w RAM). Po restarcie programu zmienna jest zerowana (bo RAM). Jak zapamiętać tą zmienną w pamięci EEPROM, aby po resecie nadal wynosiła 60? Widzę, że są odpowiednie struktury PGM_NASTAWY i EEPROM_NASTAWY, ale nie wiem jak z nich skorzystać.
PostNapisane: 17 sty 2016, o 17:51
Dołączył(a): 24 sty 2012
avrfun napisał(a):
Witam!
proponuję zobaczyć i pooglądać to: http://mirekk36.blogspot.com/2012/11/avr-eeprom-struktury-poradnik-do-ksiazek.html
Na pewno wiele się wyjaśni i będzie wiadomo jak używać ;)
PostNapisane: 17 sty 2016, o 20:52
MirkoT napisał(a):
proponuję zobaczyć i pooglądać to: http://mirekk36.blogspot.com/2012/11/av ... iazek.html
Obejrzałem dokładnie. Przykład z poradnika wykonałem na zestawie ATB. Działa prawidłowo. Analogia jest bardzo duża, a większość funkcji identyczna. Jeżeli "odpaliłeś" przykład dołączony do generatora menu to napisz proszę. Mam kilka pytań.
PostNapisane: 17 sty 2016, o 22:31
Trudności pokonane :D
Wszystko działa jak należy. Jeszcze raz bardzo dziękuję Autorowi za program.
PostNapisane: 19 sty 2016, o 12:57
na początku dziękuję za priva od użytkownika @avrfun. Dzięki mailowi o wiadomości zobaczyłem, że coś się tu dzieje.
Nie jestem ostatnio aktywny na forum ani nie robię nic w kierunku poszerzania swojej wiedzy elektronicznej i programistycznej. Jest mi z tym źle, ale może Wasze zainteresowanie w tym temacie zmusi mnie do działania. Nie było mnie tutaj dawno i nawet nie widziałem, że piszecie w tym temacie.
Do rzeczy. kolega @avrfun prosi o poprawienie błędów pojawiających się przy kompilacji. Proponuję, że do końca tygodnia wrzucę poprawioną wersję i wtedy odpowiem na pytania jeśli jeszcze jakieś się pojawią. Proszę o sugestie czego jeszcze brakuję, a może pokuszę się o dodanie jakiś nowych, pomocnych funkcji.
Pozdrawiam serdecznie
btw. Gry elektroniczne to jedna z największych uzależniaczy jakie przerabiam/łem. Udało mi się rzucić tytoń, zbyt częsty sok jabłkowy i inne różne rzeczy, ale gierki w sieci są niestety tak beztroskie i tak niewinne, że człowiek sam nie wie w czym jest problem.
PostNapisane: 19 sty 2016, o 14:58
Bardzo dziękuję!
Na gorąc obserwacja.
Tworzę MENU -> tworzę PODMENU1 -> chcę dodać funkcję (funkcja1) dla PODMENU1.
Muszę to zrobić tak:
PODMENU1 -> tworzę dowolne podmenu dla PODMENU1 np. POD_PODMENU_1 i dopiero wówczas mogę zamienić POD_PODMENU_1 na funkcję (funkcja1) poprzez użycie "Stwórz funkcję". Użycie klawisza "Stwórz funkcję" po kliknięciu na PODMENU1 zamieni je na funkcję, a nie o to chodzi. Dodatkowy krok - stwórz podmenu i zamień je na funkcję. Czy to jest zamierzona reakcja programu?
PostNapisane: 8 lut 2016, o 08:47
dziękuję za pomoc @avrfun. Program po poprawkach wstawiony w 1 poście, który został edytowany.
Pojawił się mały problem związany z samą kompilacją plików z kodem.
Ja osobiście na Windows 7, na eclipse luna(nie wiem jaki dokładnie toolchain itd), nie mam żadnych warningów, na drugim komputerze z win 10 i Eclipse Mars, najnowsze aktualizacje posiadam warning:
warning (variable 'previous_menu' set but not used [-Wunused-but-set-variable]):
Natomiast kolega @avrfun posiada takie warningi:
(pointer targets in passing argument 1 of 'lcd_str_P' differ in signedness [-Wpointer-sign])
i
Ktoś wie jak zrobić bardziej "uniwersalny" kod żeby tego typu konflikty się nie pojawiały?
PostNapisane: 14 lut 2016, o 14:26
A uzywasz gdziekolwiek tej zmiennej? Bo komunikat o tym właśnie prawi.
Sent from my mobile.
