Teraz jest 27 wrz 2026, o 02:18
PostNapisane: 19 gru 2014, o 18:29
Dołączył(a): 23 lip 2013
Hej!
Odkopałem swoje Arduino i okazuje się, że kupiłem do niego także Shield ARD GRAPH132, taki jak na filmiku:
https://www.youtube.com/watch?v=uIyC6h6G8kI
Poszukuję do niego biblioteki. Pobrałem już np. tę stąd:
http://and-tech.pl/arduino/
Lecz okazuje się, że przykład w niej zawarty nie działa. Dostaję takie błędy:
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
lcd_menu.pde: In function 'void setup()':
lcd_menu:113: error: 'class Nokia_lcd' has no member named 'cLCD_Init'
lcd_menu:114: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu.pde: In function 'void loop()':
lcd_menu:135: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:139: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:143: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:147: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:154: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:156: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu.pde: In function 'void charmap()':
lcd_menu:186: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:190: error: 'class Nokia_lcd' has no member named 'cLCD_Char'
lcd_menu:194: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:195: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu.pde: In function 'void bitmap()':
lcd_menu:208: error: 'class Nokia_lcd' has no member named 'cLCD_Bitmap'
lcd_menu:210: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:211: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu.pde: In function 'void colorbar()':
lcd_menu:233: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:234: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:236: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:237: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu.pde: In function 'void menu_action()':
lcd_menu:244: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:245: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:246: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:247: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:248: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu.pde: In function 'void about()':
lcd_menu:253: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:254: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:255: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:256: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:257: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu.pde: In function 'void init_MENU()':
lcd_menu:266: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:267: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:268: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:269: error: 'class Nokia_lcd' has no member named 'cLCD_Box'
lcd_menu:270: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:271: error: 'class Nokia_lcd' has no member named 'cLCD_String'
lcd_menu:275: error: 'class Nokia_lcd' has no member named 'cLCD_String'
Macie jakieś pomysły skąd te błędy mogą wynikać? Ewentualnie jakąś inną bibliotekę? Bo nie do końca rozumiem te komunikaty.
PostNapisane: 19 gru 2014, o 19:27
Dołączył(a): 28 wrz 2014
Cos mi to patrzy na brak include'a z definicją klasy. Jesli kompilujesz lcd_menu, to tam jest
#include "Nokia_lcd.h"
A powinno być
#include "../../Nokia_lcd.h"
żeby sciągnąć z folderu dwa poziomy niżej.
Nie dam sobie nic uciąć, ale tak myślę.
Natomiast nie wiem, dlaczego kompilator nie płacze o tego include'a??
PostNapisane: 20 gru 2014, o 09:58
Dzięki za pomysł. Mi się w ogóle nie podoba za bardzo ten kompilator i chyba się przerzucę do Eclipse albo Atmel Studio.
Niestety, ale po poprawkach ze ścieżką dostępu dostaję inne błędy:
lcd_menu.pde:2:29: error: ../../Nokia_lcd.h: No such file or directory
lcd_menu:75: error: 'Nokia_lcd' does not name a type
lcd_menu:113: error: 'lcd' was not declared in this scope
lcd_menu:114: error: 'FILL' was not declared in this scope
lcd_menu:114: error: 'LIGHTBLUE' was not declared in this scope
lcd_menu:135: error: 'lcd' was not declared in this scope
lcd_menu:135: error: 'BLUE' was not declared in this scope
lcd_menu:135: error: 'WHITE' was not declared in this scope
lcd_menu:139: error: 'CYAN' was not declared in this scope
lcd_menu:139: error: 'MAGENTA' was not declared in this scope
lcd_menu:154: error: 'FILL' was not declared in this scope
lcd_menu:186: error: 'lcd' was not declared in this scope
lcd_menu:186: error: 'FILL' was not declared in this scope
lcd_menu:186: error: 'WHITE' was not declared in this scope
lcd_menu:190: error: 'BLACK' was not declared in this scope
lcd_menu:190: error: 'CYAN' was not declared in this scope
lcd_menu:194: error: 'BLUE' was not declared in this scope
lcd_menu:208: error: 'lcd' was not declared in this scope
lcd_menu:210: error: 'FILL' was not declared in this scope
lcd_menu:210: error: 'BLUE' was not declared in this scope
lcd_menu:211: error: 'WHITE' was not declared in this scope
lcd_menu:219: error: 'WHITE' was not declared in this scope
lcd_menu:219: error: 'BLACK' was not declared in this scope
lcd_menu:219: error: 'RED' was not declared in this scope
lcd_menu:219: error: 'GREEN' was not declared in this scope
lcd_menu:219: error: 'BLUE' was not declared in this scope
lcd_menu:219: error: 'CYAN' was not declared in this scope
lcd_menu:219: error: 'MAGENTA' was not declared in this scope
lcd_menu:219: error: 'YELLOW' was not declared in this scope
lcd_menu:233: error: 'lcd' was not declared in this scope
lcd_menu:233: error: 'FILL' was not declared in this scope
lcd_menu:236: error: 'lcd' was not declared in this scope
lcd_menu:236: error: 'FILL' was not declared in this scope
lcd_menu:244: error: 'lcd' was not declared in this scope
lcd_menu:244: error: 'FILL' was not declared in this scope
lcd_menu:244: error: 'WHITE' was not declared in this scope
lcd_menu:245: error: 'BLUE' was not declared in this scope
lcd_menu:247: error: 'BLACK' was not declared in this scope
lcd_menu:253: error: 'lcd' was not declared in this scope
lcd_menu:253: error: 'FILL' was not declared in this scope
lcd_menu:253: error: 'WHITE' was not declared in this scope
lcd_menu:254: error: 'BLUE' was not declared in this scope
lcd_menu:256: error: 'BLACK' was not declared in this scope
lcd_menu:266: error: 'lcd' was not declared in this scope
lcd_menu:266: error: 'FILL' was not declared in this scope
lcd_menu:266: error: 'RED' was not declared in this scope
lcd_menu:267: error: 'BLACK' was not declared in this scope
lcd_menu:268: error: 'WHITE' was not declared in this scope
lcd_menu:269: error: 'BLUE' was not declared in this scope
lcd_menu:271: error: 'CYAN' was not declared in this scope
lcd_menu:271: error: 'MAGENTA' was not declared in this scope
Tak jakby te rzeczy nie były zadeklarowane
Od razu takie pytanie, bo trochę nie pasuje mi to środowisko, jak i gotowce. Dlatego chciałbym wrócić do czystego C w Atmel Studio, da radę to jakoś zrobić? Jak wybieram nowy projekt to widzę, że akurat Arduino Uno nie ma.
PostNapisane: 20 gru 2014, o 14:19
Moja rada, tak jak ja zrobiłem:
Obejrzyj poradniki Mirka od pierwszego do ostatniego. Jest i o przerabianiu bibliotek arduino na C.
Eclipse rulez, żadne inne IDE. Dlaczego? Bo Mirek wszystko tłumaczy od A do Z w poradnikach.
Kup Bluebooka jak nie masz. Ja niby programowalem, wprawdzie dość dawno, i myślałem że znam C, ale książka i poradniki mi to usystematyzowały i poszerzyły.
Popatrz na blog Mirka:
http://mirekk36.blogspot.com/
Są tam poradniki, zacznij od tych najstarszych.
A jesli chodzi o kod, to teraz po prostu nie znajduje include'a. Pokombinuj ze ścieżką żeby go znalazł, pewnie tak jak poprzednio. Dziwne, bo jesli miał include'a, to nie widział definicji klasy, tak jakby nie kompilował pliku cpp....
PostNapisane: 23 gru 2014, o 10:37
W sumie to z tej książki uczyłem się C. Blog też znam. A wcześniej programowałem w Eclipse.
A dlaczego Atmel Studio? Bo chciałem zobaczyć coś co bardziej przypomina np. Rolling Studio.
PostNapisane: 10 sty 2015, o 23:38
Jak idzie?
PostNapisane: 30 sty 2015, o 18:42
No słabo, słabo. Nic nie osiągnąłem i na razie odpuściłem przez zajęcia na uczelni.
