Teraz jest 20 wrz 2026, o 13:00
PostNapisane: 30 sty 2014, o 00:45
Dołączył(a): 24 cze 2012
Witam Was!
Mam zainstalowany VMWare Workstation, a na nim Windows 7 (32). Przy kopiowaniu plików przez sieć z lokalnego na wirtualny (LAN w opcji bridged) wywala mi bluescreen. Oto log ze zdarzenia zarejestrowanego przez Podgląd zdarzeń Windows:
Log Name:      System
Source:        Microsoft-Windows-DistributedCOM
Date:          2014-01-30 00:37:56
Event ID:      10016
Task Category: None
Level:         Error
Keywords:      Classic
User:          SYSTEM
Computer:      Miki-PC
Description:
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
{C97FCC79-E628-407D-AE68-A06AD6D8B4D1}
 and APPID
{344ED43D-D086-4961-86A6-1106F4ACAD9B}
 to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC). This security permission can be modified using the Component Services administrative tool.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
    <EventID Qualifiers="49152">10016</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2014-01-29T23:37:56.000000000Z" />
    <EventRecordID>9015</EventRecordID>
    <Correlation />
    <Execution ProcessID="0" ThreadID="0" />
    <Channel>System</Channel>
    <Computer>Miki-PC</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="param1">application-specific</Data>
    <Data Name="param2">Local</Data>
    <Data Name="param3">Launch</Data>
    <Data Name="param4">{C97FCC79-E628-407D-AE68-A06AD6D8B4D1}</Data>
    <Data Name="param5">{344ED43D-D086-4961-86A6-1106F4ACAD9B}</Data>
    <Data Name="param6">NT AUTHORITY</Data>
    <Data Name="param7">SYSTEM</Data>
    <Data Name="param8">S-1-5-18</Data>
    <Data Name="param9">LocalHost (Using LRPC)</Data>
  </EventData>
</Event>
Zna się ktoś na tym na tyle, aby pomóc mi znaleźć przyczynę i rozwiązanie? Widzę, że chodzi o jakiś nieuprawniony dostęp, ale nie mam pojęcia jak to zmienić :)
Lokalny system to Win7 64 :)
Pozdrawiam:
Mikołaj
PostNapisane: 30 sty 2014, o 06:22
Dołączył(a): 02 gru 2012
Po pierwsze polecam ci darmowego Oracle VirtualBox. Sam stawiam na nim duzo systemów, serwerów i innych zabawek włączając w to MacOS ;-)
Po drugie log mówi coś o uprawnieniach - dziwne.
Jaka wersja VMWare?
Wysłane z mojego GT-I9100 przy użyciu Tapatalka
PostNapisane: 30 sty 2014, o 22:29
W zasadzie już sobie poradziłem, na angielskim forum wyczytałem, że problemem jest drukarka WiFi, trzeba było gdzieś tam dodać głęboko użytkownika "SYSTEM USER" do jakiegoś uprawnienia i problem zniknął. VBox używam też, ale nie mogę na nim przekierować ATB-FT na wirtualną maszynę, a VMWare działa idealnie :) VMware 10.0.1
Pozdrawiam i dzięki za zainteresowanie.
Pozdrawiam:
Mikołaj
