Teraz jest 7 lis 2026, o 07:22
PostNapisane: 25 cze 2013, o 14:28
Jeżeli też was denerwuje co chwilę ustawianie swojego rozmiaru Grid ;) w eagle to polecam pogrzebać w pliku Eagle.....\scr\eagle.scr
Czyli po każdym tytule np. BRD: SCH: wystarczy umieścić
Grid mil 50 On; dla głównego Grid 50milsów
Grid ALT mil 5; po alt 5milsów
Można oczywiście ustawić też w mm jak komuś nie pasują milsy ;).
# Configuration Script
# This file can be used to configure the editor windows.
BRD:
Grid mil 20 On;
Grid ALT mil 2;
MENU '[designlink22.png] Search and order : Run designlink-order.ulp -general;'\
     '[pcb-service.png] PCB Service : Run pcb-service.ulp;'
#Menu Add Change Copy Delete Display Grid Group Move Name Quit Rect \
#     Route Script Show Signal Split Text Value Via Window ';'  Wire Write Edit;
SCH:
Grid mil 50 On;
Grid ALT mil 5;
MENU '[designlink22.png] Search and order {\
                                          General : Run designlink-order.ulp -general; |\
                                          Schematic : Run designlink-order.ulp; \
Change Width 0.006;
#Menu Add Bus Change Copy Delete Display Gateswap Grid Group Invoke Junction \
#     Label Move Name Net Pinswap Quit Script Show Split Value Window ';' \
#     Wire Write Edit;
LBR:
Grid mil 50 On;
Grid ALT mil 5;
#Menu Close Export Open Script Write ';' Edit;
DEV:
Grid mil 50 On;
Grid ALT mil 5;
#Menu Add Change Copy Connect Delete Display Export Grid Move Name Package \
#     Prefix Quit Script Show Value Window ';' Write Edit;
SYM:
Grid mil 50 On;
Grid ALT mil 5;
Change Width 0.010;
#Menu Arc Change Copy Cut Delete Display Export Grid Group Move Name Paste \
#     Pin Quit Script Show Split Text Value Window ';' Wire Write Edit;
PAC:
Grid mil 50 On;
Grid ALT mil 5;
Change Width 0.005;
Change Size 0.050;
#Menu Add Change Copy Delete Display Grid Group Move Name Pad Quit \
#     Script Show Smd Split Text Window ';' Wire Write Edit;
