Teraz jest 16 lis 2026, o 09:47
PostNapisane: 2 lut 2022, o 13:08
Dołączył(a): 02 lut 2022
Koledzy jak zastąpić funkcję delay przy soundX() , delay powoduje blokowanie odczytu z CAN .
#include <SPI.h>          //SPI is used to talk to the CAN Controller
#include <mcp_can.h>
#include <defaults.h> // added
#include <global.h>   // added
const int buzzerPin = 8; //Led is buzzer connected to pin 8 added
MCP_CAN CAN(10);          //set SPI Chip Select to pin 10
unsigned char len = 0;
unsigned char buf[8];
unsigned int canID;
//******************************** Setup *********************************//
void setup()
  Serial.begin(115200);   //to communicate with Serial monitor
  pinMode(buzzerPin, OUTPUT); //Set digital pin 8 to OUTPUT for buzzer
//tries to initialize, if failed --> it will loop here for ever
START_INIT:
    if(CAN_OK == CAN.begin(CAN_500KBPS))      //setting CAN baud rate to 500Kbps
        Serial.println("CAN BUS Shield init ok!");
    else
        Serial.println("CAN BUS Shield init fail");
        Serial.println("Init CAN BUS Shield again");
        nosound();
        delay(100);
        goto START_INIT;
void sound1() // for distance 1
          digitalWrite(buzzerPin, HIGH); // problemem jest delay przytyka działanie jak wykożystać millis?
          delay(500);
          digitalWrite(buzzerPin, LOW); //
void sound2() // for distance 2
          digitalWrite(buzzerPin, HIGH); //Set buzzer on
          delay(300);
          digitalWrite(buzzerPin, LOW); //Set buzzer off
void sound3() // for distance 3
          digitalWrite(buzzerPin, HIGH); //Set LED on
          delay(100);
          digitalWrite(buzzerPin, LOW); //Set LED off
void sound4() // for distance 4
          delay(50);
void nosound() // for stop buzzer
void loop()
    if(CAN_MSGAVAIL == CAN.checkReceive())        //check if data coming
        CAN.readMsgBuf(&len, buf);    //read data,  len: data length, buf: data buffer
        canID = CAN.getCanId();       //getting the ID of the incoming message
        CAN.init_Mask(0, 0, 0x200);
        if (canID == 0x200)            //reading only our beloved 0x597 message
          Serial.print("ID is: ");
          Serial.print(canID, HEX);     //printing the ID in its standard form, HEX
          Serial.print("    Length is: ");
          Serial.println(len);
          Serial.println("\n\n");
          // ** distance signal read
          if((buf[0] == 0x40) )
            Serial.println("Byte 0 Sygnał odległości : 1 +");
            sound1();
          if((buf[0] == 0x41) )
            Serial.println("Byte 0 Sygnał odległości 2 : ++");
            sound2();
          if((buf[0] == 0x42) )
            Serial.println("Byte 0 Sygnał odległości 3 : +++");
            sound3();
          if((buf[0] == 0x43) )
            sound4();
          else if((buf[0] | 0x40, 0x41, 0x42, 0x43) )
            Serial.println("no data");
            nosound();
PostNapisane: 2 lut 2022, o 14:44
Dołączył(a): 23 sty 2014
np tak:
język cpp
Aczkolwiek jest to nieeleganckie bo wprowadza w pętli głównej opóźnienie 1ms ale coś za coś
