Teraz jest 27 lip 2026, o 15:03
PostNapisane: 13 maja 2015, o 20:15
Dołączył(a): 25 sie 2013
Witam...nie mam sił już nawet zbytnio się rozpisywać. Po dwóch dniach walki z konfiguracją Eclipsa wszystko sypie sie na linkowaniu:
'Building target: libsterownik_boxer.elf'
'Invoking: Cross GCC Linker'
arm-none-eabi-gcc -T "C:/STM32/Workspace/sterownik_boxer/stm32_flash.ld" -mthumb -mcpu=cortex-m0 -Wl,--gc-sections -shared -o "libsterownik_boxer.elf" ./syscalls/syscalls.o ./stm32_lib/src/24c64.o ./stm32_lib/src/delay.o ./stm32_lib/src/pcf8385.o ./stm32_lib/src/sht2x.o ./stm32_lib/src/stm32f0xx_adc.o ./stm32_lib/src/stm32f0xx_dma.o ./stm32_lib/src/stm32f0xx_exti.o ./stm32_lib/src/stm32f0xx_gpio.o ./stm32_lib/src/stm32f0xx_i2c.o ./stm32_lib/src/stm32f0xx_misc.o ./stm32_lib/src/stm32f0xx_rcc.o ./stm32_lib/src/stm32f0xx_rtc.o ./stm32_lib/src/stm32f0xx_spi.o ./stm32_lib/src/stm32f0xx_syscfg.o ./stm32_lib/src/stm32f0xx_tim.o ./stm32_lib/src/stm32f0xx_usart.o ./stm32_lib/src/syscalls.o ./stm32_lib/src/system_gpio.o ./stm32_lib/src/tsl2561.o ./stm32_lib/HD44780.o ./stm32_lib/i2c_devices.o ./stm32_lib/system_exti.o ./stm32_lib/system_rcc.o ./stm32_lib/system_timer.o ./stm32_lib/tm_stm32f4_ds18b20.o ./stm32_lib/tm_stm32f4_onewire.o ./cmsis_boot/startup/startup_stm32f0xx.o ./cmsis_boot/stm32f0xx_it.o ./cmsis_boot/system_stm32f0xx.o ./main.o
c:/program files (x86)/gnu tools arm embedded/4.9 2015q1/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: libsterownik_boxer.elf section `.text' will not fit in region `FLASH'
c:/program files (x86)/gnu tools arm embedded/4.9 2015q1/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 78744 bytes
c:/program files (x86)/gnu tools arm embedded/4.9 2015q1/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: BFD (GNU Tools for ARM Embedded Processors) 2.24.0.20150304 assertion fail /home/build/work/GCC-4-9-build/src/binutils/bfd/elf32-arm.c:7696
c:/program files (x86)/gnu tools arm embedded/4.9 2015q1/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: error: required section '.rel.plt' not found in the linker script
c:/program files (x86)/gnu tools arm embedded/4.9 2015q1/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: final link failed: Invalid operation
collect2.exe: error: ld returned 1 exit status
make: *** [libsterownik_boxer.elf] Error 1
21:07:35 Build Finished (took 12s.172ms)
Konfigurację przeprowadziłem na podstawie jednego z marnych tutoriali w Internecie (pełno różnych tutoriali, przedstawiających milion kombinacji...co tutorial to totalnie inaczej to wygląda i sumarycznie nie wiem już nic.)
http://elektronika2014.blogspot.com/201 ... i-arm.html
PostNapisane: 13 maja 2015, o 20:22
no cóz miałeś pecha ....
spróbuj inaczej ... np:
http://www.sunduino.pl/wordpress/eclips ... rm-part-1/
http://www.sunduino.pl/wordpress/eclips ... nk-segger/
http://www.sunduino.pl/wordpress/kepler ... t-linkiem/
PostNapisane: 14 maja 2015, o 15:19
Dołączył(a): 02 lut 2014
[ciach]
[ciach reszta]
Nie za duży program chcesz załadować do procka ?
PostNapisane: 21 maja 2015, o 17:59
Dobra poradziłem sobie z kompilowaniem, choć pomijam fakt, że ten sam kod skompilowany pod działającym i wcześniej używanym środowiskiem CoCoox działa dobrze, natomiast skompilowany projekt, wygenerowany hex oraz wrzucony do procka powoduje zawieszenie go najprawdopodobniej na pierwszej lepszej linijce "assert_param" z biblioteki ST, po czym procek idzie w las. Ale po kolei. Morduje się teraz z dodaniem ST-Linka...znów pomijam fakt, że gdb server nie działa (coś musi być nawalone ze sterownikami, mam najnowszy firmware ST-Link/V2, dll'ka od stlinka w wersji 4.4.0 czy jakoś tak), open OCD też nie działa - unable to load file. Narazie to pomijam - zasadnicze pytanie - walczę aby móc używać clean...za cholerę nie mogę to skonfigurować. Gdy w opcjach projektu wybieram komendy czyszczenia jako "rm" otrzymuję w wyniku:
18:51:58 **** Clean-only build of configuration Debug for project STM32_Boxer ****
make rm
make: *** No rule to make target `rm'. Stop.
Jeśli zastosuję clean otrzymuję:
18:58:21 **** Clean-only build of configuration Debug for project STM32_Boxer ****
make clean
clean -rf ./system/src/std/stm32f0xx_adc.o ./system/src/std/stm32f0xx_dma.o ./system/src/std/stm32f0xx_exti.o ./system/src/std/stm32f0xx_gpio.o ./system/src/std/stm32f0xx_i2c.o ./system/src/std/stm32f0xx_misc.o ./system/src/std/stm32f0xx_rcc.o ./system/src/std/stm32f0xx_syscfg.o ./system/src/std/stm32f0xx_tim.o ./system/src/std/stm32f0xx_usart.o ./system/src/newlib/_cxx.o ./system/src/newlib/_exit.o ./system/src/newlib/_sbrk.o ./system/src/newlib/_startup.o ./system/src/newlib/_syscalls.o ./system/src/newlib/assert.o ./system/src/diag/Trace.o ./system/src/diag/trace_impl.o ./system/src/cortexm/_initialize_hardware.o ./system/src/cortexm/_reset_hardware.o ./system/src/cortexm/exception_handlers.o ./system/src/cmsis/system_stm32f0xx.o ./system/src/cmsis/vectors_stm32f0xx.o ./src/24c64.o ./src/HD44780.o ./src/_write.o ./src/delay.o ./src/main.o ./src/pcf8385.o ./src/sht2x.o ./src/system_exti.o ./src/system_gpio.o ./src/system_rcc.o ./src/system_timer.o ./src/tsl2561.o STM32_Boxer.hex STM32_Boxer.siz ./system/src/std/stm32f0xx_adc.d ./system/src/std/stm32f0xx_dma.d ./system/src/std/stm32f0xx_exti.d ./system/src/std/stm32f0xx_gpio.d ./system/src/std/stm32f0xx_i2c.d ./system/src/std/stm32f0xx_misc.d ./system/src/std/stm32f0xx_rcc.d ./system/src/std/stm32f0xx_syscfg.d ./system/src/std/stm32f0xx_tim.d ./system/src/std/stm32f0xx_usart.d ./system/src/newlib/_exit.d ./system/src/newlib/_sbrk.d ./system/src/newlib/_startup.d ./system/src/newlib/_syscalls.d ./system/src/newlib/assert.d ./system/src/diag/Trace.d ./system/src/diag/trace_impl.d ./system/src/cortexm/_initialize_hardware.d ./system/src/cortexm/_reset_hardware.d ./system/src/cortexm/exception_handlers.d ./system/src/cmsis/system_stm32f0xx.d ./system/src/cmsis/vectors_stm32f0xx.d ./src/24c64.d ./src/HD44780.d ./src/_write.d ./src/delay.d ./src/main.d ./src/pcf8385.d ./src/sht2x.d ./src/system_exti.d ./src/system_gpio.d ./src/system_rcc.d ./src/system_timer.d ./src/tsl2561.d ./system/src/newlib/_cxx.d STM32_Boxer.elf
process_begin: CreateProcess(NULL, clean -rf ./system/src/std/stm32f0xx_adc.o ./system/src/std/stm32f0xx_dma.o ./system/src/std/stm32f0xx_exti.o ./system/src/std/stm32f0xx_gpio.o ./system/src/std/stm32f0xx_i2c.o ./system/src/std/stm32f0xx_misc.o ./system/src/std/stm32f0xx_rcc.o ./system/src/std/stm32f0xx_syscfg.o ./system/src/std/stm32f0xx_tim.o ./system/src/std/stm32f0xx_usart.o ./system/src/newlib/_cxx.o ./system/src/newlib/_exit.o ./system/src/newlib/_sbrk.o ./system/src/newlib/_startup.o ./system/src/newlib/_syscalls.o ./system/src/newlib/assert.o ./system/src/diag/Trace.o ./system/src/diag/trace_impl.o ./system/src/cortexm/_initialize_hardware.o ./system/src/cortexm/_reset_hardware.o ./system/src/cortexm/exception_handlers.o ./system/src/cmsis/system_stm32f0xx.o ./system/src/cmsis/vectors_stm32f0xx.o ./src/24c64.o ./src/HD44780.o ./src/_write.o ./src/delay.o ./src/main.o ./src/pcf8385.o ./src/sht2x.o ./src/system_exti.o ./src/system_gpio.o ./src/system_rcc.o ./src/system_timer.o ./src/tsl2561.o STM32_Boxer.hex STM32_Boxer.siz ./system/src/std/stm32f0xx_adc.d ./system/src/std/stm32f0xx_dma.d ./system/src/std/stm32f0xx_exti.d ./system/src/std/stm32f0xx_gpio.d ./system/src/std/stm32f0xx_i2c.d ./system/src/std/stm32f0xx_misc.d ./system/src/std/stm32f0xx_rcc.d ./system/src/std/stm32f0xx_syscfg.d ./system/src/std/stm32f0xx_tim.d ./system/src/std/stm32f0xx_usart.d ./system/src/newlib/_exit.d ./system/src/newlib/_sbrk.d ./system/src/newlib/_startup.d ./system/src/newlib/_syscalls.d ./system/src/newlib/assert.d ./system/src/diag/Trace.d ./system/src/diag/trace_impl.d ./system/src/cortexm/_initialize_hardware.d ./system/src/cortexm/_reset_hardware.d ./system/src/cortexm/exception_handlers.d ./system/src/cmsis/system_stm32f0xx.d ./system/src/cmsis/vectors_stm32f0xx.d ./src/24c64.d ./src/HD44780.d ./src/_write.d ./src/delay.d ./src/main.d ./src/pcf8385.d ./src/sht2x.d ./src/system_exti.d ./src/system_gpio.d ./src/system_rcc.d ./src/system_timer.d ./src/tsl2561.d ./system/src/newlib/_cxx.d STM32_Boxer.elf, ...) failed.
make (e=2): Nie można odnaleźć określonego pliku.
make: [clean] Error 2 (ignored)
Czy jakiś dobry człowiek jest w stanie pomóc ? Konfiguracja Eclipse mnie ciut przerasta, nie myślałem, że to takie popier******. :) Z góry dzięki !
EDIT:
A to np. wypis na konsolę po skonfigurowaniu sobie programowania z poziomu narzędzia ST Link CLI:
STM32 ST-LINK CLI v2.1.0
STM32 ST-LINK Command Line Interface
ST-LINK SN : 50FF73064977535529310587
ST-LINK Firmware version : V2J23S0
Connected via SWD.
SWD Frequency = 1800K.
Connection mode : Normal.
Device ID:0x440
Device flash Size : 64 Kbytes
Device family :STM32F051x4/F051x6/F051x8/F030x8
Loading file...
Flash Programming:
File : C:\STM32\Workspace\STM32_Boxer\Debug\STM32_Boxer.hex
Address : 0x08000230
Flash memory programming...
Flash memory programmed in 1s and 716ms.
Programming Complete.
MCU Reset.
The core is locked up!
PostNapisane: 21 maja 2015, o 18:51
Podałem na tacy .. łacznie z gotowym keplerem pod STlinka i J-Linka
Jakiej jeszcze pomocy oczekujesz ??
PostNapisane: 21 maja 2015, o 20:45
Dokładnie z tych poradników jechałem
PostNapisane: 21 maja 2015, o 21:00
a czy trudno pobrać gotowy kepler ??
jedyne co masz zrobić potem to wskazać miejsce instalacji toolchaina
GNU ARM EABI
