Teraz jest 30 cze 2026, o 11:23
PostNapisane: 7 paź 2014, o 20:25
Dołączył(a): 16 sie 2014
W książce Pana Mirka Kardasia przepisałem całą biblotekę do plików LCD.h LCD.c main.c
i w funkcji inicjalizującej nie wiem skąd nagle wzięły się takie bity, które po skompilowaniu jak widzimy pojawiają się jako błędy.
Nie wiem do czego one służą, czy nie dołączyłem jakiejś biblioteki ? :
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(154,17): error: 'LCDC_FUNC' undeclared (first use in this function)
        lcd_write_cmd( LCDC_FUNC|LCDC_FUNC4B|LCDC_FUNC2L|LCDC_FUNC5x7 );
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(154,17): info: each undeclared identifier is reported only once for each function it appears in
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(154,27): error: 'LCDC_FUNC4B' undeclared (first use in this function)
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(154,39): error: 'LCDC_FUNC2L' undeclared (first use in this function)
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(154,51): error: 'LCDC_FUNC5x7' undeclared (first use in this function)
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(156,17): error: 'LCDC_ONOFF' undeclared (first use in this function)
        lcd_write_cmd( LCDC_ONOFF|LCDC_CURSOROFF );
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(156,28): error: 'LCDC_CURSOROFF' undeclared (first use in this function)
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(158,28): error: 'LCDC_DISPLAYON' undeclared (first use in this function)
        lcd_write_cmd( LCDC_ONOFF|LCDC_DISPLAYON );
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(160,17): error: 'LCDC_ENTRY' undeclared (first use in this function)
        lcd_write_cmd( LCDC_ENTRY|LCDC_ENTRYR );
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(160,28): error: 'LCDC_ENTRYR' undeclared (first use in this function)
      .././LCD.c: In function '_lcd_write_byte':
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(204,2): error: 'CLR_RW' undeclared (first use in this function)
        CLR_RW;
      .././LCD.c: In function 'lcd_cls':
C:\Users\Admin\Documents\Atmel Studio\6.2\LCD\LCD\LCD.c(237,17): error: 'LCDC_CLS' undeclared (first use in this function)
        lcd_write_cmd( LCDC_CLS );
Przy okazji chciałem też spytać jak zdefiniować F_CPU dla biblioteki <util/delay.h> ?
PostNapisane: 7 paź 2014, o 20:39
Dołączył(a): 19 gru 2012
Na twoim miejscu nie szukałbym problemów w bibliotece bo uwierz że są w 10000% sprawne i każdy z z posiadaczy z nich korzysta. Błędów bym szukał w Atmel Studia lub toolchainie.
Na płytce masz gotowy kod wiec po co przepisujesz?
Co do F_CPU to nigdy nie definiujemy tego w kodzie, po to są ustawienia projektu aby tam ustawić taktowanie dla wszystkich plików całego projektu.
PostNapisane: 7 paź 2014, o 20:42
ok, Dzięki, a do czego służą te bity ? do odczytu flagi zajętości ?
PostNapisane: 7 paź 2014, o 21:09
Panie kochany - bój się Zeusa - a czytałeś chociaż raz książkę ? :(
a zaglądałeś na płytę DVD dołączoną do niej - masz tam kody i co więcej masz Eclipse i wszystko gotowe do kompilacji
na DVD masz też LEKCJE VIDEO - zaglądałeś ? po obejrzeniu pierwszej już wiadomo o co chodzi i jak to odpalić w eclipse a nie w kocim atmel studio
PostNapisane: 7 paź 2014, o 21:35
Dołączył(a): 03 mar 2014
Heh, panie Mirku będę chyba pana zmorą jeżeli chodzi o AS :D
Kolega po co przepisywać tą bibliotekę? Przecież wystarczy dodać ją do projektu :)
Tak to się robi:
1. W pliku main.c załączasz tylko: #include "LCD.h"
2. W okienku Solution Explorer (prawa strona - takie węższe okienko) klikasz na ikonkę z nazwą Twojego projektu prawym przyciskiem myszy. Rozwija się menu, dajesz ADD i następnie Existing Item. Tak dodajesz dwa pliku LCD.c oraz LCD.h.
Warto również zrobić Add -> New Folder. Nazwać go przykładowo LCD. Wtedy to klikasz PPM na ten folder i dodajesz jak wyżej. Include się zmieni w tym momencie na taki: #include "LCD/LCD.h"
z Niebieskim pozdRowieniem,
Doman89
PostNapisane: 7 paź 2014, o 21:38
Spokojnie - pomagaj ;)
PostNapisane: 7 paź 2014, o 21:41
F_CPU dodajemy w ten sposób:
1. Project -> [nazwa_projektu] Properties...
2. Toolchain
3. AVR/GNU C Compiler -> Symbols
4. W okienku Defines symbols (-D) kilkamy dokument z zielonym plusikiem
5. W oknie co wyjdzie wpisujemy: "F_CPU=8000000UL" dla 8MHz, dla innych analogicznie
Doman89
PostNapisane: 7 paź 2014, o 21:51
Dziękuje za pomoc!
