Teraz jest 29 sty 2025, o 23:32
PostNapisane: 10 cze 2014, o 19:50
Dołączył(a): 09 gru 2013
Witam wszystkich!
Przy kompilacji folderu z całym projektem wyskakuje mi w okienku console poniższy komunikat:
**** Build of configuration Release for project NEW_TWO ****
make all
Building file: ../i2chw/twimaster.c
Invoking: AVR Compiler
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega8 -DF_CPU=8000000UL -MMD -MP -MF"i2chw/twimaster.d" -MT"i2chw/twimaster.d" -c -o "i2chw/twimaster.o" "../i2chw/twimaster.c"
Finished building: ../i2chw/twimaster.c
Building file: ../bmp085/bmp085.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega8 -DF_CPU=8000000UL -MMD -MP -MF"bmp085/bmp085.d" -MT"bmp085/bmp085.d" -c -o "bmp085/bmp085.o" "../bmp085/bmp085.c"
Finished building: ../bmp085/bmp085.c
Building file: ../LCD/lcd44780.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega8 -DF_CPU=8000000UL -MMD -MP -MF"LCD/lcd44780.d" -MT"LCD/lcd44780.d" -c -o "LCD/lcd44780.o" "../LCD/lcd44780.c"
Finished building: ../LCD/lcd44780.c
Building file: ../main.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega8 -DF_CPU=8000000UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c"
Finished building: ../main.c
Building target: NEW_TWO.elf
Invoking: AVR C Linker
avr-gcc -Wl,-Map,NEW_TWO.map -mmcu=atmega8 -o "NEW_TWO.elf" ./i2chw/twimaster.o ./bmp085/bmp085.o ./LCD/lcd44780.o ./main.o
c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: NEW_TWO.elf section .text will not fit in region text
c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: region text overflowed by 270 bytes
make: *** [NEW_TWO.elf] Error 1
**** Build Finished ****
Poszczególne elementy kompilują się bez problemu (lcd, i2c, bmp085).
Co jest nie tak?
PostNapisane: 10 cze 2014, o 20:10
Dołączył(a): 06 maja 2012
Normalnie nie mieści się. Masz włączoną optymalizację?
Project>Properties>C/C++ Build>Settings>AVR Compiler>Optimization
PostNapisane: 10 cze 2014, o 20:16
Dołączył(a): 22 gru 2013
Tak na szybko ; wygląda na przepełnienie pamięci programu ( text overflowed).
Może pomoże clean projektu, ew. spróbuj tymczasowo "odchudzić" projekt, wyciąć nie używane funkcje.
PostNapisane: 10 cze 2014, o 20:25
jest zaznaczone size optimizations
PostNapisane: 10 cze 2014, o 20:31
Prawdopodobinie bmp085.c zabiera bardzo dużo. Nie ma rady. Musisz zagospodarować 270 bajtów albo albo zmienić procek na Atmega168.
PostNapisane: 10 cze 2014, o 21:15
Wymieniłem procek na ATmege168P i taka dziwna sprawa: MkAVRkalkulator wykrywa go bez problemu, a w eclipsie ustawiam ręcznie (przy load from MCU wyskakuje błąd). Projek kompiluje sią bez błędu a przy próbie wgrania eclipse krzyczy błąd rc=-1....
PostNapisane: 10 cze 2014, o 21:32
Dołączył(a): 28 sty 2013
Bo zapewne masz nie przestawione fusebity i procek leci na 1MHz. Zmień w MkAvrCalculator na taktowanie np. 8MHz i przeprogramuj fusebity. Po tym zabiegu procek w Eclipsie powinien być wykrywany.
PostNapisane: 10 cze 2014, o 21:57
Nie pomogło
Pomógł restart komputera
PostNapisane: 13 cze 2014, o 13:13
Czy mógłby mi ktoś jeszcze powiedzieć co zmienić w kodzie aby wartość była wyświetlana w hPa zamiast Pa?
Taka operacja pomaga
ale
generalnie wynik wyświetlany w Pa zawiera 5 cyfr. Zależałoby mi żeby jednak 2 ostatnie cyfry wyniku zostawały i był po przecinku.
PostNapisane: 16 cze 2014, o 08:01
Witam!
Mam jeszcze kolejne pytaniem Mam podłączony moduł GY-65 na płytce stykowej z atmegą168. Zasilam to baterią 9V (bateria w obudowie z włącznikiem) i przetwornicą obniżam do 5V. Po włączeniu zasilania z baterii przełącznikiem na obudowie zawsze najpierw otrzymuję taki obraz
Gdy wyłącze zasilanie i podam je po raz kolejny to już wszystko działa ok
Co może być nie tak?
W karcie czujnika bmp085 na którym opiera się moduł gy-65 jest napsane, że powinien być zasilany napięciem 1,8-3,6 V ale znalazłem informację że cały moduł gy-65 możne być zasilany 5V.
PostNapisane: 16 cze 2014, o 10:09
mokrowski napisał(a):
Co do 2 linijek zapalonych to jest to objaw w tym sensie prawidłowy że wyświetlacz został podłączony poprawnie. Nie został jednak zainicjalizowany poprawnie gdzieś masz błąd w sekwencji inicjalizacji.
Nie wiem czy zapytałeś, ale wyświetlacze 4x20 (taki jaki masz) są traktowane jako 2 wyświetlacze x 2x20 i mają
dodatkową linię sterującą wyboru połówki wyświetlacza,
W takim razie mam kolejne pytanie czy jeżeli byłby błąd w sekwencji inicjalizacji to po podłączeniu innego czujnika wszystko działałoby ok? (tzn. po podaniu zasilania od razu wyświetlają się wyniki pomiaru)
PostNapisane: 16 cze 2014, o 16:07
Ten akurat ma jedną linię E.
PostNapisane: 16 cze 2014, o 19:56
Wyświetlacz 4x20
link do noty katalogowej:
http://www.artronic.com.pl/o_produkcie.php?id=586
