Teraz jest 19 wrz 2026, o 16:14
PostNapisane: 23 kwi 2014, o 21:19
Dołączył(a): 18 sie 2012
mam taki problem ze w arduino nie moge uploadowąc hex do atmegi 644p przez programator bitbang na ftdi232 , chodzi ze jak dodam opcje -D np w eclipse to działa prawidłowo lecz w arduino i pochodnych pluginow np stino do sublime dostaje komunikat taki
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega644p -cATB-FT232R -Uflash:w:/tmp/build6269229091108644299.tmp/atb_test.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 6 2014 at 08:24:02
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/foreste/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : ATB-FT232R
avrdude: <unknown>: Pin is ok.
avrdude: VCC: Pin is ok.
avrdude: BUFF: Pin is ok.
avrdude: RESET: Pin is ok.
avrdude: SCK: Pin is ok.
avrdude: MOSI: Pin is ok.
avrdude: MISO: Pin is ok.
avrdude: ERRLED: Pin is ok.
avrdude: RDYLED: Pin is ok.
avrdude: PGMLED: Pin is ok.
avrdude: VFYLED: Pin is ok.
ft245r: spi bitclk 75000 -> ft baudrate 150000
AVR Part : ATmega644P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 2048 8 0 9000 9000 0xff 0xff
flash 33 6 256 0 yes 65536 256 256 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : ftdi_syncbb
Description : ATB-FT232R ATNEL
Pin assignment : 0..7 = DBUS0..7
VCC = (not used)
BUFF = (not used)
RESET = 7
SCK = 5
MOSI = 6
MISO = 3
ERR LED = (not used)
RDY LED = (not used)
PGM LED = (not used)
VFY LED = (not used)
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e960a
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: Program enable command not successful. Retrying.
avrdude: Device is not responding to program enable. Check connection.
avrdude done. Thank you.
czy ja tylko mam ten problem na atb i z 644p i jeśli to można poprawić to jaki sposób ?.
PostNapisane: 24 kwi 2014, o 14:19
Dołączył(a): 13 paź 2011
foreste, opcja -D w avrdude powoduje wyłączenie auto kasowania pamięci flash i jest ona w Arduino 1.0.x domyślnie ustawiona, bo gdyby było inaczej to za każdym razem podczas ładowania (UPLOAD) swojego programu kasowany byłby Bootloader, a tego nie chcemy - więc za bardzo nie rozumiem o co Ci chodzi.
pozdrawiam
phill2k
PostNapisane: 25 kwi 2014, o 11:36
Jest już dobrze wyniklo ze ja zle skompilowalem avrdude nie dodalem patcha poprawe resetu programatora/zestawu do avrdude i przez to takie problemy.
a to wynik koncowy
avrdude: Version 6.1-20140313, compiled on Apr 25 2014 at 11:54:30
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : usb
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
VCC = (not used)
BUFF = (not used)
RESET = 7
SCK = 5
MOSI = 6
MISO = 3
avrdude: reading input file "/tmp/build8418299514344553516.tmp/atb_test.cpp.hex"
avrdude: writing flash (1278 bytes):
Writing | ################################################## | 100% 0.37s
avrdude: 1278 bytes of flash written
avrdude: verifying flash memory against /tmp/build8418299514344553516.tmp/atb_test.cpp.hex:
avrdude: load data flash data from input file /tmp/build8418299514344553516.tmp/atb_test.cpp.hex:
avrdude: input file /tmp/build8418299514344553516.tmp/atb_test.cpp.hex contains 1278 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.33s
avrdude: avr_read(): skipping page 5: no interesting data
avrdude: avr_read(): skipping page 6: no interesting data
avrdude: avr_read(): skipping page 7: no interesting data
avrdude: avr_read(): skipping page 8: no interesting data
avrdude: avr_read(): skipping page 9: no interesting data
avrdude: avr_read(): skipping page 10: no interesting data
avrdude: avr_read(): skipping page 11: no interesting data
avrdude: avr_read(): skipping page 12: no interesting data
avrdude: avr_read(): skipping page 13: no interesting data
avrdude: avr_read(): skipping page 14: no interesting data
avrdude: avr_read(): skipping page 15: no interesting data
avrdude: avr_read(): skipping page 16: no interesting data
avrdude: avr_read(): skipping page 17: no interesting data
avrdude: avr_read(): skipping page 18: no interesting data
avrdude: avr_read(): skipping page 19: no interesting data
avrdude: avr_read(): skipping page 20: no interesting data
avrdude: avr_read(): skipping page 21: no interesting data
avrdude: avr_read(): skipping page 22: no interesting data
avrdude: avr_read(): skipping page 23: no interesting data
avrdude: avr_read(): skipping page 24: no interesting data
avrdude: avr_read(): skipping page 25: no interesting data
avrdude: avr_read(): skipping page 26: no interesting data
avrdude: avr_read(): skipping page 27: no interesting data
avrdude: avr_read(): skipping page 28: no interesting data
avrdude: avr_read(): skipping page 29: no interesting data
avrdude: avr_read(): skipping page 30: no interesting data
avrdude: avr_read(): skipping page 31: no interesting data
avrdude: avr_read(): skipping page 32: no interesting data
avrdude: avr_read(): skipping page 33: no interesting data
avrdude: avr_read(): skipping page 34: no interesting data
avrdude: avr_read(): skipping page 35: no interesting data
avrdude: avr_read(): skipping page 36: no interesting data
avrdude: avr_read(): skipping page 37: no interesting data
avrdude: avr_read(): skipping page 38: no interesting data
avrdude: avr_read(): skipping page 39: no interesting data
avrdude: avr_read(): skipping page 40: no interesting data
avrdude: avr_read(): skipping page 41: no interesting data
avrdude: avr_read(): skipping page 42: no interesting data
avrdude: avr_read(): skipping page 43: no interesting data
avrdude: avr_read(): skipping page 44: no interesting data
avrdude: avr_read(): skipping page 45: no interesting data
avrdude: avr_read(): skipping page 46: no interesting data
avrdude: avr_read(): skipping page 47: no interesting data
avrdude: avr_read(): skipping page 48: no interesting data
avrdude: avr_read(): skipping page 49: no interesting data
avrdude: avr_read(): skipping page 50: no interesting data
avrdude: avr_read(): skipping page 51: no interesting data
avrdude: avr_read(): skipping page 52: no interesting data
avrdude: avr_read(): skipping page 53: no interesting data
avrdude: avr_read(): skipping page 54: no interesting data
avrdude: avr_read(): skipping page 55: no interesting data
avrdude: avr_read(): skipping page 56: no interesting data
avrdude: avr_read(): skipping page 57: no interesting data
avrdude: avr_read(): skipping page 58: no interesting data
avrdude: avr_read(): skipping page 59: no interesting data
avrdude: avr_read(): skipping page 60: no interesting data
avrdude: avr_read(): skipping page 61: no interesting data
avrdude: avr_read(): skipping page 62: no interesting data
avrdude: avr_read(): skipping page 63: no interesting data
avrdude: avr_read(): skipping page 64: no interesting data
avrdude: avr_read(): skipping page 65: no interesting data
avrdude: avr_read(): skipping page 66: no interesting data
avrdude: avr_read(): skipping page 67: no interesting data
avrdude: avr_read(): skipping page 68: no interesting data
avrdude: avr_read(): skipping page 69: no interesting data
avrdude: avr_read(): skipping page 70: no interesting data
avrdude: avr_read(): skipping page 71: no interesting data
avrdude: avr_read(): skipping page 72: no interesting data
avrdude: avr_read(): skipping page 73: no interesting data
avrdude: avr_read(): skipping page 74: no interesting data
avrdude: avr_read(): skipping page 75: no interesting data
avrdude: avr_read(): skipping page 76: no interesting data
avrdude: avr_read(): skipping page 77: no interesting data
avrdude: avr_read(): skipping page 78: no interesting data
avrdude: avr_read(): skipping page 79: no interesting data
avrdude: avr_read(): skipping page 80: no interesting data
avrdude: avr_read(): skipping page 81: no interesting data
avrdude: avr_read(): skipping page 82: no interesting data
avrdude: avr_read(): skipping page 83: no interesting data
avrdude: avr_read(): skipping page 84: no interesting data
avrdude: avr_read(): skipping page 85: no interesting data
avrdude: avr_read(): skipping page 86: no interesting data
avrdude: avr_read(): skipping page 87: no interesting data
avrdude: avr_read(): skipping page 88: no interesting data
avrdude: avr_read(): skipping page 89: no interesting data
avrdude: avr_read(): skipping page 90: no interesting data
avrdude: avr_read(): skipping page 91: no interesting data
avrdude: avr_read(): skipping page 92: no interesting data
avrdude: avr_read(): skipping page 93: no interesting data
avrdude: avr_read(): skipping page 94: no interesting data
avrdude: avr_read(): skipping page 95: no interesting data
avrdude: avr_read(): skipping page 96: no interesting data
avrdude: avr_read(): skipping page 97: no interesting data
avrdude: avr_read(): skipping page 98: no interesting data
avrdude: avr_read(): skipping page 99: no interesting data
avrdude: avr_read(): skipping page 100: no interesting data
avrdude: avr_read(): skipping page 101: no interesting data
avrdude: avr_read(): skipping page 102: no interesting data
avrdude: avr_read(): skipping page 103: no interesting data
avrdude: avr_read(): skipping page 104: no interesting data
avrdude: avr_read(): skipping page 105: no interesting data
avrdude: avr_read(): skipping page 106: no interesting data
avrdude: avr_read(): skipping page 107: no interesting data
avrdude: avr_read(): skipping page 108: no interesting data
avrdude: avr_read(): skipping page 109: no interesting data
avrdude: avr_read(): skipping page 110: no interesting data
avrdude: avr_read(): skipping page 111: no interesting data
avrdude: avr_read(): skipping page 112: no interesting data
avrdude: avr_read(): skipping page 113: no interesting data
avrdude: avr_read(): skipping page 114: no interesting data
avrdude: avr_read(): skipping page 115: no interesting data
avrdude: avr_read(): skipping page 116: no interesting data
avrdude: avr_read(): skipping page 117: no interesting data
avrdude: avr_read(): skipping page 118: no interesting data
avrdude: avr_read(): skipping page 119: no interesting data
avrdude: avr_read(): skipping page 120: no interesting data
avrdude: avr_read(): skipping page 121: no interesting data
avrdude: avr_read(): skipping page 122: no interesting data
avrdude: avr_read(): skipping page 123: no interesting data
avrdude: avr_read(): skipping page 124: no interesting data
avrdude: avr_read(): skipping page 125: no interesting data
avrdude: avr_read(): skipping page 126: no interesting data
avrdude: avr_read(): skipping page 127: no interesting data
avrdude: avr_read(): skipping page 128: no interesting data
avrdude: avr_read(): skipping page 129: no interesting data
avrdude: avr_read(): skipping page 130: no interesting data
avrdude: avr_read(): skipping page 131: no interesting data
avrdude: avr_read(): skipping page 132: no interesting data
avrdude: avr_read(): skipping page 133: no interesting data
avrdude: avr_read(): skipping page 134: no interesting data
avrdude: avr_read(): skipping page 135: no interesting data
avrdude: avr_read(): skipping page 136: no interesting data
avrdude: avr_read(): skipping page 137: no interesting data
avrdude: avr_read(): skipping page 138: no interesting data
avrdude: avr_read(): skipping page 139: no interesting data
avrdude: avr_read(): skipping page 140: no interesting data
avrdude: avr_read(): skipping page 141: no interesting data
avrdude: avr_read(): skipping page 142: no interesting data
avrdude: avr_read(): skipping page 143: no interesting data
avrdude: avr_read(): skipping page 144: no interesting data
avrdude: avr_read(): skipping page 145: no interesting data
avrdude: avr_read(): skipping page 146: no interesting data
avrdude: avr_read(): skipping page 147: no interesting data
avrdude: avr_read(): skipping page 148: no interesting data
avrdude: avr_read(): skipping page 149: no interesting data
avrdude: avr_read(): skipping page 150: no interesting data
avrdude: avr_read(): skipping page 151: no interesting data
avrdude: avr_read(): skipping page 152: no interesting data
avrdude: avr_read(): skipping page 153: no interesting data
avrdude: avr_read(): skipping page 154: no interesting data
avrdude: avr_read(): skipping page 155: no interesting data
avrdude: avr_read(): skipping page 156: no interesting data
avrdude: avr_read(): skipping page 157: no interesting data
avrdude: avr_read(): skipping page 158: no interesting data
avrdude: avr_read(): skipping page 159: no interesting data
avrdude: avr_read(): skipping page 160: no interesting data
avrdude: avr_read(): skipping page 161: no interesting data
avrdude: avr_read(): skipping page 162: no interesting data
avrdude: avr_read(): skipping page 163: no interesting data
avrdude: avr_read(): skipping page 164: no interesting data
avrdude: avr_read(): skipping page 165: no interesting data
avrdude: avr_read(): skipping page 166: no interesting data
avrdude: avr_read(): skipping page 167: no interesting data
avrdude: avr_read(): skipping page 168: no interesting data
avrdude: avr_read(): skipping page 169: no interesting data
avrdude: avr_read(): skipping page 170: no interesting data
avrdude: avr_read(): skipping page 171: no interesting data
avrdude: avr_read(): skipping page 172: no interesting data
avrdude: avr_read(): skipping page 173: no interesting data
avrdude: avr_read(): skipping page 174: no interesting data
avrdude: avr_read(): skipping page 175: no interesting data
avrdude: avr_read(): skipping page 176: no interesting data
avrdude: avr_read(): skipping page 177: no interesting data
avrdude: avr_read(): skipping page 178: no interesting data
avrdude: avr_read(): skipping page 179: no interesting data
avrdude: avr_read(): skipping page 180: no interesting data
avrdude: avr_read(): skipping page 181: no interesting data
avrdude: avr_read(): skipping page 182: no interesting data
avrdude: avr_read(): skipping page 183: no interesting data
avrdude: avr_read(): skipping page 184: no interesting data
avrdude: avr_read(): skipping page 185: no interesting data
avrdude: avr_read(): skipping page 186: no interesting data
avrdude: avr_read(): skipping page 187: no interesting data
avrdude: avr_read(): skipping page 188: no interesting data
avrdude: avr_read(): skipping page 189: no interesting data
avrdude: avr_read(): skipping page 190: no interesting data
avrdude: avr_read(): skipping page 191: no interesting data
avrdude: avr_read(): skipping page 192: no interesting data
avrdude: avr_read(): skipping page 193: no interesting data
avrdude: avr_read(): skipping page 194: no interesting data
avrdude: avr_read(): skipping page 195: no interesting data
avrdude: avr_read(): skipping page 196: no interesting data
avrdude: avr_read(): skipping page 197: no interesting data
avrdude: avr_read(): skipping page 198: no interesting data
avrdude: avr_read(): skipping page 199: no interesting data
avrdude: avr_read(): skipping page 200: no interesting data
avrdude: avr_read(): skipping page 201: no interesting data
avrdude: avr_read(): skipping page 202: no interesting data
avrdude: avr_read(): skipping page 203: no interesting data
avrdude: avr_read(): skipping page 204: no interesting data
avrdude: avr_read(): skipping page 205: no interesting data
avrdude: avr_read(): skipping page 206: no interesting data
avrdude: avr_read(): skipping page 207: no interesting data
avrdude: avr_read(): skipping page 208: no interesting data
avrdude: avr_read(): skipping page 209: no interesting data
avrdude: avr_read(): skipping page 210: no interesting data
avrdude: avr_read(): skipping page 211: no interesting data
avrdude: avr_read(): skipping page 212: no interesting data
avrdude: avr_read(): skipping page 213: no interesting data
avrdude: avr_read(): skipping page 214: no interesting data
avrdude: avr_read(): skipping page 215: no interesting data
avrdude: avr_read(): skipping page 216: no interesting data
avrdude: avr_read(): skipping page 217: no interesting data
avrdude: avr_read(): skipping page 218: no interesting data
avrdude: avr_read(): skipping page 219: no interesting data
avrdude: avr_read(): skipping page 220: no interesting data
avrdude: avr_read(): skipping page 221: no interesting data
avrdude: avr_read(): skipping page 222: no interesting data
avrdude: avr_read(): skipping page 223: no interesting data
avrdude: avr_read(): skipping page 224: no interesting data
avrdude: avr_read(): skipping page 225: no interesting data
avrdude: avr_read(): skipping page 226: no interesting data
avrdude: avr_read(): skipping page 227: no interesting data
avrdude: avr_read(): skipping page 228: no interesting data
avrdude: avr_read(): skipping page 229: no interesting data
avrdude: avr_read(): skipping page 230: no interesting data
avrdude: avr_read(): skipping page 231: no interesting data
avrdude: avr_read(): skipping page 232: no interesting data
avrdude: avr_read(): skipping page 233: no interesting data
avrdude: avr_read(): skipping page 234: no interesting data
avrdude: avr_read(): skipping page 235: no interesting data
avrdude: avr_read(): skipping page 236: no interesting data
avrdude: avr_read(): skipping page 237: no interesting data
avrdude: avr_read(): skipping page 238: no interesting data
avrdude: avr_read(): skipping page 239: no interesting data
avrdude: avr_read(): skipping page 240: no interesting data
avrdude: avr_read(): skipping page 241: no interesting data
avrdude: avr_read(): skipping page 242: no interesting data
avrdude: avr_read(): skipping page 243: no interesting data
avrdude: avr_read(): skipping page 244: no interesting data
avrdude: avr_read(): skipping page 245: no interesting data
avrdude: avr_read(): skipping page 246: no interesting data
avrdude: avr_read(): skipping page 247: no interesting data
avrdude: avr_read(): skipping page 248: no interesting data
avrdude: avr_read(): skipping page 249: no interesting data
avrdude: avr_read(): skipping page 250: no interesting data
avrdude: avr_read(): skipping page 251: no interesting data
avrdude: avr_read(): skipping page 252: no interesting data
avrdude: avr_read(): skipping page 253: no interesting data
avrdude: avr_read(): skipping page 254: no interesting data
avrdude: avr_read(): skipping page 255: no interesting data
avrdude: verifying ...
avrdude: 1278 bytes of flash verified
a tu jest mój temat topic6760.html gdzie udostępniam avrdude pod linuxa dla ft232/245r
PostNapisane: 25 kwi 2014, o 12:06
Dołączył(a): 25 sty 2014
offtopic foreste dodawaj jakos zwięzłej te kody błedów bo ciezko czytac posty
np przez code synax c wtedy ladnie zawija i jak ktos chce przejrzec caly log to sobie moze rozwinąc
