KURS HOME ASSISTANT
    Teraz jest 12 maja 2025, o 13:15
    PostNapisane: 12 lut 2014, o 16:06
    Dołączył(a): 18 sie 2012
    Witam mam do sprzedania karte muzyczną firmy Creative
    Sound blaster pci 128
    model ct4700
    Detailed item info
    Description
    Immerse yourself in the gaming experience with the Sound Blaster PCI128. Designed for the home user, gamer or multimedia enthusiast, you can hear every gunshot and experience the enemy sneaking up behind you. Use the four-speaker output to truly experience real 3D sound! The Sound Blaster PCI128 utilizes the PCI bus, allowing it to use far less CPU overhead than traditional sound cards. This translates into higher frame rates in your games, more bandwidth for 3D audio and multi-channel support for upcoming game titles.For professional music playback, the Creative synthesis engine provides 128-voices of wave-table sound. User selectable sample banks let you choose the quality level you want. Now every instrument sounds just like its real life counterpart, not a poor facsimile. Because it uses Sound Blaster PCI technology you won't have to worry about compatibility. Creative's patented technology provides near-perfect Sound Blaster emulation. This means that the Sound Blaster PCI128 works with the existing base of MS-DOS and Windows titles. So if you are ready for the next level of gaming audio, step up to the Sound Blaster PCI128.
    Product Identifiers
    Brand Creative
    Product Line Creative Sound Blaster
    Model PCI 128
    MPN CT4700
    Main Specification
    Type Sound card
    Enclosure Type Laptop Card
    Interface Type PCI
    DAC Data Width 16-bit
    Sample Rate 4 kHz - 48 kHz
    Sound Output Mode 2.0
    Connectivity 1 x audio - line-in - mini-phone stereo 3.5 mm - 1, 1 x audio - line-out - mini-phone stereo 3.5 mm - 1, 1 x gameport / MIDI - generic - 15 pin D-Sub (DB-15) - 1, 1 x microphone - input - mini-phone mono 3.5 mm - 1
    System Requirements
    Operation System Required Microsoft Windows 95/98, Microsoft Windows NT 4.0
    Platform Compatibility PC
    Software Required Drivers & Utilities
    Min Ram Required 16 MB
    Processor Type Required Intel Pentium 133 MHz
    Audio Output
    Voice Polyphony Quantity 128
    MIDI Channels Quantity 16
    Environmental Parameters
    Humidity Range Operating 30 - 80%
    Minimum Operating Temperature 10 °C
    Maximum Operating Temperature 50 °C
    Karta działa na linux windows xp/vista/7 i prawdopodobnie na win8
    Fotka podglądowa
    http://www.hattix.co.uk/hardware/ct4700_big.jpg
    Cena 35zl do negocjacji.
    Dostawa wysyłka
