Teraz jest 31 sie 2026, o 10:10
PostNapisane: 5 lut 2014, o 20:34
Dołączył(a): 22 kwi 2013
Mam problem z zapisaniem fusbitów dla atmega328p i 88p . Programator Usbasp fischl program mkAVR.
Problem dotyczy tylko tych procków i tylko z mkAVR, w Eclipsie wsad ładuje bezbłędnie. Atmege8 zapisauje poprawnie.
log z konsoli;
avrdude: set SCK frequency to 0 Hz
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xD9"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xD9:
avrdude: load data hfuse data from input file 0xD9:
avrdude: input file 0xD9 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: writing efuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.03s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFF:
avrdude: load data efuse data from input file 0xFF:
avrdude: reading on-chip efuse data:
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x07
avrdude: verification error; content mismatch
avrdude done. Thank you.
https://www.facebook.com/jacekplichtaphotography/
PostNapisane: 5 lut 2014, o 21:34
Zabawa się rozkręca ;-( przy kolejnej próbie ustawienia fusbitów atmega328p przestała się "odzywać" Hmm....
mkAVR juz go nie wykrywa. Po włożeniu atmegi88 jest sytuacja wyjściowa czyli Eclips wgrywa flash natomiast
mkAVR widzi go ale jest błąd przy próbie zapisu. Wgrywałem już inny wsad do programatora ze strony fischl.de, i
averdude przez mkAVR ale nic to nie zmieniło.
PostNapisane: 5 lut 2014, o 21:48
nie włączaj weryfikacji fusebitów przy ich zapisie do procka - to nie będzie komunikatu błędu ;) ... ale nawet ten komunikat nic złego nie robi z fusami - więc na razie - to co opisujesz to tylko problem taki że coś robisz za szybko, denerwujesz się i nagle jest chaos ;)
zapewniam cię że akurat procki m88/168/328 to jedne z NAJCZĘSCIEJ używanych przeze mnie ;)
PostNapisane: 5 lut 2014, o 22:08
Trafiony zatopiony :D ale jak tu się nie denerwować jak mija kolejna
godzina, próbujesz setne i tysięczne potencjalne rozwiązanie problemu
a tu z każdą minutą się pogrążasz :x A może jest wszystko w porządku
a ja szukam dziury w całym?
