Teraz jest 20 lut 2025, o 16:22
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 63 ]  Przejdź na stronę 1, 2, 3  Następna strona
 Tytuł: 1Wire
PostNapisane: 11 sty 2014, o 20:12
Dołączył(a): 30 gru 2013
Jak należy zmienić program z niebieskiej książki 1Wire aby działał na procesorze ATMega168? Po zmianie procesora we właściwościach projektu w Eclipse (używam WinAVR-20100110), mam następujące błędy:
**** Build of configuration Release for project 10_1Wire ****
make all
Building file: ../LCD/lcd44780.c
Invoking: AVR Compiler
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega168 -DF_CPU=11059200UL -MMD -MP -MF"LCD/lcd44780.d" -MT"LCD/lcd44780.d" -c -o "LCD/lcd44780.o" "../LCD/lcd44780.c"
../LCD/lcd44780.c: In function 'data_dir_out':
../LCD/lcd44780.c:48: error: 'DDRA' undeclared (first use in this function)
../LCD/lcd44780.c:48: error: (Each undeclared identifier is reported only once
../LCD/lcd44780.c:48: error: for each function it appears in.)
../LCD/lcd44780.c: In function 'data_dir_in':
../LCD/lcd44780.c:61: error: 'DDRA' undeclared (first use in this function)
../LCD/lcd44780.c: In function 'lcd_sendHalf':
../LCD/lcd44780.c:74: error: 'PORTA' undeclared (first use in this function)
../LCD/lcd44780.c: In function 'lcd_readHalf':
../LCD/lcd44780.c:90: error: 'PINA' undeclared (first use in this function)
../LCD/lcd44780.c: In function '_lcd_write_byte':
../LCD/lcd44780.c:110: error: 'PORTA' undeclared (first use in this function)
../LCD/lcd44780.c: In function '_lcd_read_byte':
../LCD/lcd44780.c:140: error: 'PORTA' undeclared (first use in this function)
../LCD/lcd44780.c: In function 'check_BF':
../LCD/lcd44780.c:163: error: 'PORTA' undeclared (first use in this function)
../LCD/lcd44780.c: In function 'lcd_write_cmd':
../LCD/lcd44780.c:176: error: 'PORTA' undeclared (first use in this function)
../LCD/lcd44780.c: In function 'lcd_write_data':
../LCD/lcd44780.c:187: error: 'PORTA' undeclared (first use in this function)
../LCD/lcd44780.c: In function 'lcd_init':
../LCD/lcd44780.c:483: error: 'DDRA' undeclared (first use in this function)
../LCD/lcd44780.c:490: error: 'PORTA' undeclared (first use in this function)
make: *** [LCD/lcd44780.o] Error 1
**** Build Finished ****
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 20:17
Dołączył(a): 07 lut 2013
ATMega168 niema portu A.
Zmień port w pliku lcd44780.h np. na B
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 20:30
OK. Częściowo pomogło. Jednak dalej coś jest nie tak:
make all
Building file: ../main.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega168 -DF_CPU=11059200UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c"
../main.c:30: error: 'TCCR0' undeclared (first use in this function)
../main.c:30: error: (Each undeclared identifier is reported only once
../main.c:30: error: for each function it appears in.)
../main.c:32: error: 'OCR0' undeclared (first use in this function)
../main.c:33: error: 'TIMSK' undeclared (first use in this function)
../main.c:33: error: 'OCIE0' undeclared (first use in this function)
../main.c: At top level:
../main.c:121: warning: 'TIMER0_COMP_vect' appears to be a misspelled signal handler
make: *** [main.o] Error 1
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 20:36
Dla tego procka trzeba będzie inaczej skonfigurować Taimer.
Ten który został zawarty w kodzie był dla ATmega32.
Zerknij do noty katalogowej twojego procka.
------------------------ [ Dodano po: 19 minutach ]
I jak dobrze pamiętam był to tryb CTC dla Timer0 a ATMega168 go nie posiada dla Timer0
------------------------ [ Dodano po: 26 minutach ]
Zerknąłem tak na szybko do noty i ATMega168 ma CTC na Timer2, tylko to będzie wymagało małych modyfikacji w inicjacji i nazwie wektora przerwania ale w nocie wszystko znajdziesz.
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 21:19
Dołączył(a): 29 sty 2012
W Atmedze168 tryb CTC mają wszystkie trzy Timery. Jeśli wszystkie to Timer0 też. Trochę inaczej się tylko rejestry nazywają dlatego wywaliło błędy związane z obsługą Timera0.
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 21:35
Fakt bije się w pierś.
Pisałem to jeszcze z głowy zanim zajrzałem do noty.
Na pewno taki przypadek miałem przy ATmega8.
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 22:38
Więc co muszę zmienić w poniższym kodzie?
/* ustawienie TIMER0 dla F_CPU=11,0592MHz */
   TCCR0 |= (1<<WGM01);            /* tryb CTC */
   TCCR0 |= (1<<CS02)|(1<<CS00);      /* preskaler = 1024 */
   OCR0 = 108;                     /* dodatkowy podział przez 108 (rej. przepełnienia) */
   TIMSK |= (1<<OCIE0);            /* zezwolenie na przerwanie CompareMatch */
   /* przerwanie wykonywane z częstotliwością ok 10ms (100 razy na sekundę) */
   /* do naszych celów nie musi być to bardzo dokładne 10ms */
 Tytuł: Re: 1Wire
PostNapisane: 11 sty 2014, o 23:43
Zajrzyj do noty pdf Atmegi168 do rozdziału 14.9 Register Description. Tam masz opisane wszystkie rejestry Timera0.
Ale co tam, każdy był kiedyś początkujący :-)
Konfiguracja przerwania powinna wyglądać tak:
No i obsługa przerwania
I jeszcze jedno. Kody wstawiaj w znacznikach syntax a nie code. Wtedy są o bardziej czytelne.
 Tytuł: Re: 1Wire
PostNapisane: 12 sty 2014, o 12:32
OK. Dzięki za pomoc. Mam jeszcze 2 pytania. Jeśli chcę podłączyć czujnik temperatury do PINu PB0, to w następującym fragmencie kodu (onewire.h) zmieniam tylko PB1 na PB0?
Drugie pytania, do procesora muszę dołączyć kwarc 11,0592 MHz do PINów oznaczonych XTAL1 i XTAL2, przez 2 kondensatory np. 22 pF, czyli w programie mkAVR Calculator w zakładce Fusy uproszczone, ustawiam zewnętrzny kwarc > 8 MHz, a następnie wgrywam mój program przez Eclipse?
 Tytuł: Re: 1Wire
PostNapisane: 12 sty 2014, o 12:38
Tak tylko tutaj.
 Tytuł: Re: 1Wire
PostNapisane: 12 sty 2014, o 12:43
1.Tak zmieniasz PB1 na PB0.
2. A kwarc nie podłączasz poprzez kondensatory tylko bezpośrednio to pinów XTAL1 i XTAL2, a jedne końce kondensatorów podłączasz do GND a drugie do końcówek kwarca. Wtedy musisz przestawić procka na zewnętrzne taktowanie ustawiając czyli > 8MHz.
 Tytuł: Re: 1Wire
PostNapisane: 12 sty 2014, o 12:46
Po ustawieniu Fus-ów zapisz je, sprawdź połączenie w mkAVR Calculator a następnie wgraj wsad.
Z tego co widziałem z powyższego listingu to kwarc w eclipsie masz już ustawiony na tą częstotliwość.
 Tytuł: Re: 1Wire
PostNapisane: 13 sty 2014, o 13:46
Po podłączeniu kwarcu, ustawieniu częstotliwości w mkAVRCalculator, wgraniu programu, otrzymuję napis na wyświetlaczu:
   T1               T2
error              error
Czujnik podłączyłem do PINu PD7. W pliku onewire.h ustawiłem:
Co może być nie tak?
 Tytuł: Re: 1Wire
PostNapisane: 13 sty 2014, o 14:36
Pokaż cały kod main.c, jakąś fotkę co i jak popodpinane.
A tak na gorąco to czy masz podciągniętą linie danych do VCC dla DS18....
 Tytuł: Re: 1Wire
PostNapisane: 13 sty 2014, o 15:00
Linie danych czujnika mam podpiętą do VCC przez rezystor 4,7k
 Tytuł: Re: 1Wire
PostNapisane: 13 sty 2014, o 16:34
Sprawdzi miernikiem czy masz vcc na rezystorze podciągającym, wnioskuje po mostkach że może nie dochodzi.
Niestety nie znam tej stykówki, w mojej te rzędy pionowe są podzielone na dwie części.
 Tytuł: Re: 1Wire
PostNapisane: 13 sty 2014, o 20:15
Tak, mam połączenie miedzy VCC a rezystorem. Rozumiem, że kod programu jest OK?
 Tytuł: Re: 1Wire
PostNapisane: 13 sty 2014, o 21:53
Wydaje mi się że jest OK.
Skompilowałem go u siebie konfigurując porty dla LCD tak jak u ciebie port B i C i port czujnika na D7 kompilacja bez błędów.
Niestety nie posiadam ATmeg-i 168 żeby to fizycznie wypróbować.
Spróbuj sprawdzić jeszcze połączenia może coś jednak nie styka.
 Tytuł: Re: 1Wire
PostNapisane: 14 sty 2014, o 17:23
Sprawdziłem wszystkie połączenia i wszystko styka, ale nadal zamiast temperatury pokazuje error.
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 18:20
Wykonaj Project->Clean i Build i pokaż zawartość okienka Console.
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 18:41
**** Clean-only build of configuration Release for project 10_1Wire ****
make clean
rm -rf  ./LCD/lcd44780.o  ./1Wire/crc8.o ./1Wire/ds18x20.o ./1Wire/onewire.o  ./main.o  ./LCD/lcd44780.d  ./1Wire/crc8.d ./1Wire/ds18x20.d ./1Wire/onewire.d  ./main.d  10_1Wire.eep  10_1Wire.hex  10_1Wire.lss  sizedummy  10_1Wire.elf
make all
Finished building: ../LCD/lcd44780.c
Building file: ../1Wire/crc8.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega168 -DF_CPU=11059200UL -MMD -MP -MF"1Wire/crc8.d" -MT"1Wire/crc8.d" -c -o "1Wire/crc8.o" "../1Wire/crc8.c"
Finished building: ../1Wire/crc8.c
Building file: ../1Wire/ds18x20.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega168 -DF_CPU=11059200UL -MMD -MP -MF"1Wire/ds18x20.d" -MT"1Wire/ds18x20.d" -c -o "1Wire/ds18x20.o" "../1Wire/ds18x20.c"
Finished building: ../1Wire/ds18x20.c
Building file: ../1Wire/onewire.c
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega168 -DF_CPU=11059200UL -MMD -MP -MF"1Wire/onewire.d" -MT"1Wire/onewire.d" -c -o "1Wire/onewire.o" "../1Wire/onewire.c"
Finished building: ../1Wire/onewire.c
Finished building: ../main.c
Building target: 10_1Wire.elf
Invoking: AVR C Linker
avr-gcc -Wl,-Map,10_1Wire.map -mmcu=atmega168 -o "10_1Wire.elf"  ./LCD/lcd44780.o  ./1Wire/crc8.o ./1Wire/ds18x20.o ./1Wire/onewire.o  ./main.o
Finished building target: 10_1Wire.elf
Invoking: AVR Create Extended Listing
avr-objdump -h -S 10_1Wire.elf  >"10_1Wire.lss"
Finished building: 10_1Wire.lss
Create Flash image (ihex format)
avr-objcopy -R .eeprom -O ihex 10_1Wire.elf  "10_1Wire.hex"
Finished building: 10_1Wire.hex
Create eeprom image (ihex format)
avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex 10_1Wire.elf  "10_1Wire.eep"
Finished building: 10_1Wire.eep
Invoking: Print Size
avr-size --format=avr --mcu=atmega168 10_1Wire.elf
AVR Memory Usage
Device: atmega168
Program:    2976 bytes (18.2% Full)
(.text + .data + .bootloader)
Data:         73 bytes (7.1% Full)
(.data + .bss + .noinit)
Finished building: sizedummy
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 19:05
Ostrzeżeń brak. F_CPU ma dobrą wartość. Program dobry. Sprawdź inny termometr. Odłącz całkowicie termometr i przenieś się w inne miejsce na stykówce.
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:22
Sprawdziłem 3 różne czujniki (w innym miejscu płytki) we wszystkich error, gdy uruchomię bez podłączonego czujnika na wyświetlaczu mam:
T1 T2
0.0 C 0.0 C
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:31
Jeżeli się mylę to niech mnie ktoś poprawi ale może to nieprzestawiony wewnętrzny podział zegara przez 8 CKDIV8 w Fus-ach. Chyba że przy zewnętrznym kwarcu on niema znaczenia.
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:35
Dołączył(a): 29 paź 2013
może rezystor daj mniejszy między 2,2k a 3,7k między vcc a odczytem z dallasa
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:37
No ślepy jestem nawet w mkAVR Calculator pisze jak byk na czerwono(Uwaga CKDIV8 dotyczy każdego taktowania).
Sprawdź czy masz wyłączony ten podział zegara przez 8 a jak nie to go odc hacz i wgraj Fusy.
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:38
też tak myślałem CKOPT może?
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:45
Odznaczenie CKDIV8 pomogło. Wielkie dzięki!
 Tytuł: Re: 1Wire
PostNapisane: 15 sty 2014, o 20:49
Małymi, małymi kroczkami i przy użyciu sił nadprzyrodzonych (intuicji) rozwiązaliśmy tą zagatkę :lol:
 Tytuł: Re: 1Wire
PostNapisane: 16 sty 2014, o 20:47
Niestety to dopiero początek problemów ;) W swoim projekcie muszę wykorzystać RS232. Wyobrażam sobie to tak, że będę przesyłał po prostu wartość temperatury na komputer. Moglibyście polecić jakąś elektronikę dzięki której będę mógł to zrobić? Najlepiej jakieś rozwiązanie sprawdzone i często używane, tak żeby zminimalizować możliwe problemy :) Bo chyba z programem na komputer obsługującym to nie ma raczej problemu?
