Teraz jest 17 kwi 2026, o 15:57
PostNapisane: 14 mar 2020, o 20:41
Dołączył(a): 14 mar 2020
Witam!
W MkEclipse po lewej stronie okna pod drzewkiem projektu nie pokazuje u mnie nic (0% Flash, 0% Ram). MkClipse czyta prawidłowo nazwę procesora ale nie zapala się ikonka AVR Upload oraz pokazuje mi się błąd w okienku:
''Invalid argument to date encode’'.
Po wygenerowaniu MkBuild files i naciśnięciu ikonki Build w konsoli pokazuje nie się błąd:
compiling process, please wait...
"C:\Users\Sebastian Hp Pavilon\Documents\MkClipse\AVR ToolchainT10\bin\avr-gcc" -Wall -Os -Wstrict-aliasing=1 -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=attiny102 -DF_CPU=8000000UL -MMD -MP -MF"Release/main.d" -MT"Release/main.o" -c -o "Release/main.o" "main.c""
avr-gcc: error: unrecognized argument in option '-mmcu=attiny102'
avr-gcc: note: valid arguments to '-mmcu=' are: at43usb320 at43usb355 at76c711 at86rf401 at90c8534 at90can128 at90can32 at90can64 at90pwm1 at90pwm161 at90pwm2 at90pwm216 at90pwm2b at90pwm3 at90pwm316 at90pwm3b at90pwm81 at90s1200 at90s2313 at90s2323 at90s2333 at90s2343 at90s4414 at90s4433 at90s4434 at90s8515 at90s8535 at90scr100 at90usb1286 at90usb1287 at90usb162 at90usb646 at90usb647 at90usb82 at94k ata5272 ata5505 ata5702m322 ata5782 ata5790 ata5790n ata5795 ata5831 ata6285 ata6286 ata6289 ata6612c ata6613c ata6614q ata6616c ata6617c ata664251 atmega103 atmega128 atmega1280 atmega1281 atmega1284 atmega1284p atmega1284rfr2 atmega128a atmega128rfa1 atmega128rfr2 atmega16 atmega161 atmega162 atmega163 atmega164a atmega164p atmega164pa atmega165 atmega165a atmega165p atmega165pa atmega168 atmega168a atmega168p atmega168pa atmega168pb atmega169 atmega169a atmega169p atmega169pa atmega16a atmega16hva atmega16hva2 atmega16hvb atmega16hvbrevb atmega16m1 atmega16u2 atmega16u4 atmega2560 atmega2561 atmega2564rfr2 atmega256rfr2 atmega32 atmega323 atmega324a atmega324p atmega324pa atmega325 atmega3250 atmega3250a atmega3250p atmega3250pa atmega325a atmega325p atmega325pa atmega328 atmega328p atmega329 atmega3290 atmega3290a atmega3290p atmega3290pa atmega329a atmega329p atmega329pa atmega32a atmega32c1 atmega32hvb atmega32hvbrevb atmega32m1 atmega32u2 atmega32u4 atmega32u6 atmega406 atmega48 atmega48a atmega48p atmega48pa atmega48pb atmega64 atmega640 atmega644 atmega644a atmega644p atmega644pa atmega644rfr2 atmega645 atmega6450 atmega6450a atmega6450p atmega645a atmega645p atmega649 atmega6490 atmega6490a atmega6490p atmega649a atmega649p atmega64a atmega64c1 atmega64hve atmega64hve2 atmega64m1 atmega64rfr2 atmega8 atmega8515 atmega8535 atmega88 atmega88a atmega88p atmega88pa atmega88pb atmega8a atmega8hva atmega8u2 attiny10 attiny11 attiny12 attiny13 attiny13a attiny15 attiny1634 attiny167 attiny20 attiny22 attiny2313 attiny2313a attiny24 attiny24a attiny25 attiny26 attiny261 attiny261a attiny28 attiny4 attiny40 attiny4313 attiny43u attiny44 attiny441 attiny44a attiny45 attiny461 attiny461a attiny48 attiny5 attiny828 attiny84 attiny841 attiny84a attiny85 attiny861 attiny861a attiny87 attiny88 attiny9 atxmega128a1 atxmega128a1u atxmega128a3 atxmega128a3u atxmega128a4u atxmega128b1 atxmega128b3 atxmega
128c3 atxmega128d3 atxmega128d4 atxmega16a4 atxmega16a4u atxmega16c4 atxmega16d4 atxmega16e5 atxmega192a3 atxmega192a3u atxmega192c3 atxmega192d3 atxmega256a3 atxmega256a3b atxmega256a3bu atxmega256a3u atxmega256c3 atxmega256d3 atxmega32a4 atxmega32a4u atxmega32c3 atxmega32c4 atxmega32d3 atxmega32d4 atxmega32e5 atxmega384c3 atxmega384d3 atxmega64a1 atxmega64a1u atxmega64a3 atxmega64a3u atxmega64a4u atxmega64b1 atxmega64b3 atxmega64c3 atxmega64d3 atxmega64d4 atxmega8e5 avr1 avr2 avr25 avr3 avr31 avr35 avr4 avr5 avr51 avr6 avrtiny avrxmega2 avrxmega4 avrxmega5 avrxmega6 avrxmega7 m3000
"C:\Users\Sebastian Hp Pavilon\Documents\MkClipse\AVR ToolchainT10\bin\avr-gcc" -Wall -Os -Wstrict-aliasing=1 -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=attiny102 -DF_CPU=8000000UL -MMD -MP -MF"Release/mk_build.d" -MT"Release/mk_build.o" -c -o "Release/mk_build.o" "mk_build.c""
ERROR
Proszę o pomoc.
Sebastian
PostNapisane: 14 mar 2020, o 22:10
A rozpakowałeś prawidłowy AVRDUDE dla MkClipse ?
PostNapisane: 14 mar 2020, o 22:26
A to nie problem ze spacjami w ścieżkach?
PostNapisane: 14 mar 2020, o 23:03
Dzięki za odpowiedź, rozpakowałem AVRDude, nie rozumiem w jakich ścieżkach poszukać spacji...?
PostNapisane: 15 mar 2020, o 00:21
Dołączył(a): 14 sie 2016
Np w tej masz spacje
PostNapisane: 15 mar 2020, o 00:30
Ok, dzięki, sprawdzę to...
PostNapisane: 15 mar 2020, o 02:33
Niestety po zainstalowaniu nowego konta i usunięciu wszystkich spacji mam podobny efekt:
"C:\Program Files (x86)\Atmel\AVR_Tools\AVR_Toolchain\bin\avr-gcc" -Wall -Os -Wstrict-aliasing=1 -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=attiny102 -DF_CPU=11059200UL -MMD -MP -MF"Release/mk_build.d" -MT"Release/mk_build.o" -c -o "Release/mk_build.o" "mk_build.c""
"C:\Program Files (x86)\Atmel\AVR_Tools\AVR_Toolchain\bin\avr-gcc" -Wall -Os -Wstrict-aliasing=1 -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=attiny102 -DF_CPU=11059200UL -MMD -MP -MF"Release/main.d" -MT"Release/main.o" -c -o "Release/main.o" "main.c""
ERROR
PostNapisane: 15 mar 2020, o 07:58
no to masz jeszcze zły TOOLCHAIN który nie rozpoznaje tego procka, w MkClipse też można zassać najnowszy toolchain i on sam się podłączy, wtedy powinien kompilować tego procka
PostNapisane: 15 mar 2020, o 08:18
Po drugie wcale nie usunąłeś wszystkich spacji. Przyjrzyj sie dokładnie.
PostNapisane: 15 mar 2020, o 09:40
chodzi o spacje dla Program Files 86? tam gdzie jest toolchain ? - to tylko uzupełnię że akurat tam mogą być spacje - to MkClipse wytrzyma ;)
Czy jeszcze w innym miejscu dojrzałeś spacje ?
A do autora wątku - zawsze się zastanawiam po jakiego grzybka ;) ? ludzie trzymają WSZYSTKO na pulpicie windowsa - przecież to zgroza i wręcz proszenie się o kłopoty jak się później coś kompiluje bo właśnie wtedy wyłażą spacje, polskie znaki itp.
WYSTARCZYŁOBY wgrać wszystko np bezpośrednio na C:\ albo na D:\
PostNapisane: 15 mar 2020, o 09:52
Tak, chodziło mi o Program Files - ja dla bezpieczeństwa trzymam wszystko na krótkich ścieżkach (i bez polskich znaków diakrytycznych) - nie tracę przez to czasu na poszukiwanie ew usterek/problemów.
PostNapisane: 15 mar 2020, o 10:19
Popieram w całej rozciągłości ;) co racja to racja
PostNapisane: 15 mar 2020, o 12:51
Dzięki za odpowiedzi i podpowiedzi. Wszystko u mnie jest na C:/ oprócz skrótów do programów które trzymam na pulpicie w folderze Programy. Mirek zaleca w poradniku do instalacji AVR Toolchain aby go zainstalować w domyślnej lokalizacji, więc nie zmieniałem ścieżki z C:/Program Files (86)/AVR Toolchain.....itd. Postaram się to zmienić i dam znać co dalej.
Dzięki za pomoc. :)
------------------------ [ Dodano po: 50 minutach ]
Zmieniłem lokalizację AVR_Toolchain i mam taki efekt:
"C:\Users\CNC\Documents\MkClipse\AVR ToolchainT10\bin\avr-gcc" -Wall -Os -Wstrict-aliasing=1 -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=attiny102 -DF_CPU=11059200UL -MMD -MP -MF"Release/main.d" -MT"Release/main.o" -c -o "Release/main.o" "main.c""
"C:\Users\CNC\Documents\MkClipse\AVR ToolchainT10\bin\avr-gcc" -Wall -Os -Wstrict-aliasing=1 -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=attiny102 -DF_CPU=11059200UL -MMD -MP -MF"Release/mk_build.d" -MT"Release/mk_build.o" -c -o "Release/mk_build.o" "mk_build.c""
ERROR
PostNapisane: 15 mar 2020, o 17:46
Jeśli ktoś mógłby mi powiedzieć dlaczego compiler nie ma definicji dla argumentu: ''attiny102'' (j/w) tylko generuje błąd:
Było by to ogromnie pomocne...
PostNapisane: 15 mar 2020, o 19:05
Dołączył(a): 09 gru 2014
Wygląda na to, że akurat ta wersja kompilatora Tiny 10 toolchain nie ma tej definicji.
Odznacz opcję Select special Tiny10 toolchain, wejdź w Help -> Download Toolchain, poczekaj aż się ściągnie i zainstaluje.
Po tym zabiegu Twoja ATtiny102 będzie śmigać. ;)
PostNapisane: 20 mar 2020, o 00:34
Niestety, też nie działa.
PostNapisane: 20 mar 2020, o 12:25
To pokaż że screenshoty z MkClipsa jak masz go ustawionego itp
PostNapisane: 22 mar 2020, o 13:34
Tak jak wspomniałam moim zdaniem avi-gcc compiler nie posiada definicji dla attiny102 więc wrzucę kilka fotek z mojego MkClipse:
1sza fotka odpalam MkClipse:
Niestety nie jestem w stanie załadować tutaj zdjęć więc wyślę Ci Mirku na maila.
PostNapisane: 22 mar 2020, o 15:07
Dołączył(a): 26 mar 2014
Tak na szybkiego w MKClipse wybrałem procka atTiny102
Pozdrawiam Paweł.
PostNapisane: 22 mar 2020, o 15:09
czy szanowny kolega nie widział poprzednio jak ktoś pisał żeby ODZNACZYĆ sobie ptaszka dla ATtiny ? trzeba korzystać z normalnego kompilatora
a odnośnie zdjęć - to proszę zapoznać się do czego służy przycisk PrintScreen i jak się nim robi zrzuty ekranu bo na prawdę takie zdjęcia przesłane telefonem i to z widokiem 1/3 okna programu .... hmmm do niczego nie są przydatne
ale widać po komunikatach że z uporem godnym podziwu kolega działa na toolchainie specjalnym dla attiny10,
TEN PTAK MASZ MIEĆ WYŁĄCZONY
przecież jak byk jest w opisie ptaka że to toolchain dla attiny10 a nie dla innych attiny
PostNapisane: 22 mar 2020, o 15:48
Chyba muszę zrobić udane gcc, czy mogę poprosić o jakiegoś wiarygodnego linka:
PostNapisane: 22 mar 2020, o 16:24
bez sensu - czy na prawdę kolega w ogóle się nie zapoznawał z możliwościami MkClipse ? nie oglądał żadnych poradników ? sorki ale aż strach bierze
przecież w Menu "HELP" MkClipse masz Download Toolchain - dlaczego go nie pobierzesz ? toż wszystko jest pod ręką
PostNapisane: 22 mar 2020, o 16:55
Przykro mi ale po pobraniu, automatycznym rozpakowaniu i zainstalowaniu (po raz drugi), program reaguje tak samo na przycisk "Build''.
Postanowiłem nie zaznaczać "ptaka" na dole przy "Select special Tiny10 toolchain" i teraz wszystko działa, nie potrafię zrozumieć tylko dlaczego...
PostNapisane: 22 mar 2020, o 17:22
od początku było mówione żebyś go nie zaznaczał a ty wciąż go zaznaczałeś ... nie wiem dlaczego
Przecież sama nazwa ptaka mówi - że jeśli go zaznaczysz to MkClipse będzie korzystało ze specjalnego (drugiego) i najlepszego toolchaina dla procków ale tylko z serii ATtiny10 (no mówię masz to jak byk napisane w opisie ptaszka)
Jeśli zaś pracuje się z innymi prockami to korzysta się z pierwszego toolchaina. Chyba widzisz że w menu HELP można pobrać DWA toolchainy i sam je pobierałeś.
Ten drugi specjalny toolchain dla ATtiny10 po prostu generuje na tej serii procków mniejszy wsad binarny. Można też kompilować dla ATtiny10 tym pierwszym toolchainem ale wsad będzie większy - więc co się bardzie opłaca?
A ty od początku masz Attiny102 i mówią ci ludzie żebyś wyłączył ptaka dla Attiny10 a ty nie - dalej swoje i zdziwienie że nie działa ;) ... teraz w końcu widzę doszedłeś że jednak trzeba go odptaszkować dla tiny102 - w końcu ;)
PostNapisane: 22 mar 2020, o 17:35
Niestety uczę się na błędach. Nie wiem czemu ale jakoś skojarzyło mi się, że ten "ptak" ma być włączony ze względu na przynależność ATtiny102 do tej grupy procesorów i tak go pozostawiłem. Dzięki za cierpliwość do mnie.
PostNapisane: 22 mar 2020, o 22:11
Jeszcze ja się podepnę pod temat z pytaniem.
Mirku w MKClipse na liście procków jest ATtiny102 i 104 a w Eclipsie już nie ma.
Wybrałem ścieżki dla toolchaina tego samego co MKClipse i nie widzę ich na liście procków. :(
A tak swoją drogą to Microchip każe się rejestrować na firmę w momencie pobierania najnowszego toolchaina. :(
PostNapisane: 23 mar 2020, o 00:50
No w Eclipse nie ma - trzeba byłoby sobie ten AVRDUDE z MkClipsa wkopiować do katalogu AVRDUDE który został zrobiony MkAvrCalculatorem ale też nie wiem czy wtedy to się uda. W MkClipse byłem w stanie dodać to dodałem ;)
