Teraz jest 30 mar 2026, o 21:09
PostNapisane: 17 lut 2017, o 14:37
Dołączył(a): 17 sie 2015
Cześć.
Prawdopodobnie zablokowałem procesor. Przez pospiech w eclipsie w ustawieniach programatora USBasp w polu: Override default port (-P): miałem wpisane -B 375. Próba wgrania programu skończyła się zawieszeń procka i komunikatem w konsoli:
Launching C:\AVRDUDE\avrdude -pm8 -cusbasp "-P-B 375" -Uflash:w:04_LCD.hex:a -Ueeprom:w:04_LCD.eep:a
Output:
Please wait ...
avrdude_mk.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% -0.00s
avrdude_mk.exe: Device signature = 0x1e9307
avrdude_mk.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude_mk.exe: current erase-rewrite cycle count is -50462977 (if being tracked)
avrdude_mk.exe: erasing chip
avrdude_mk.exe: reading input file "04_LCD.hex"
avrdude_mk.exe: input file 04_LCD.hex auto detected as Intel Hex
avrdude_mk.exe: writing flash (1268 bytes):
Writing | ################################################## | 100% 0.58s
avrdude_mk.exe: 1268 bytes of flash written
avrdude_mk.exe: verifying flash memory against 04_LCD.hex:
avrdude_mk.exe: load data flash data from input file 04_LCD.hex:
avrdude_mk.exe: input file 04_LCD.hex contains 1268 bytes
avrdude_mk.exe: reading on-chip flash data:
Reading | ################################################## | 100% 0.33s
avrdude_mk.exe: verifying ...
avrdude_mk.exe: verification error, first mismatch at byte 0x0000
0x20 != 0x00
avrdude_mk.exe: verification error; content mismatch
avrdude_mk.exe: safemode: Fuses OK
avrdude_mk.exe done. Thank you.
avrdude finished
Analiza tego co się stało, usuniecie parametru Override default port (-P) próba wgrania ponownie programu skutkuje podobnym błędem.
Launching C:\AVRDUDE\avrdude -pm8 -cusbasp -Uflash:w:04_LCD.hex:a -Ueeprom:w:04_LCD.eep:a
Output:
Please wait ...
Reading | ################################################## | 100% 0.02s
0x20 != 0x00
avrdude finished
Zostawiłem wiec w spokoju eclipsa. Przeszedłem do MkvCalkulatora próbując wgrać inne taktowanie lub ustawienia fabryczne. Niestety procesor zablokował się na tych 8 mhz i nie chce się dać przeprogramować. Czy jest szansa odblokować taki procesor?
Niestety w ten sposób załatwiłem dwa procesory atmega8, trzecia po usunięciu tego parametru z eclpisa programuje się normalnie jak i Atmega328p, wiec układ elektroniczny jest poprawny.
PostNapisane: 17 lut 2017, o 15:25
Przepraszam (nie obraź się) no ale już tak okropne bzdurki kolega wypisuje że aż się włosy na plecach prostują jak na fryzjerskiej prostownicy.
Jakie zablokowanie procka? jakim parametrem ? ... jakim Eclipse ...
Z tego co opisujesz płynie jedna ważna ... najważniejsza informacja - MEGA CHAOS , po prostu MEGA CHAOS
ja się zakładam, że żadnego procka nie zablokowałeś
weź ty usiądź i na spokojnie weź oddech - wypij szklankę chłodnej wody i zrób to co mówię:
1. włóż do PUSTEJ stykówki sam procek
2. dołóż do niego jakiegoś kwarca na wszelki wypadek
3. nie dodawaj ŻADNYCH KONDENSATORÓW ! żadnych - ani do kwarca ani do zasilania ani ŻADNYCH rezystorów do resetu itp itd
4. PODŁĄCZ POPRAWNIE zasilanie do procka na stykówce (czyli dwie linie GND , jedno VCC i jedno AVCC)
(Qurczę - zmierz napięcia na tych nogach czy są poprawne)
5. PODŁĄCZ poprawnie piny ISP czyli =: MOSI, MISO, SCK i RESET
6. Odpal MkAvrCalculator
7. w zakładce Programator - kliknij żółty klawisz "Sprawdź podłączony AVR"
- jeśli zrobisz to wszystko i ci nie odczyta procka to wtedy POKAŻ tu ze dwa zdjęcia tego jak ty to połączyłeś - ale mówię DOKŁADNIE wg tego opisu - i żeby było widać jak prowadzisz linie ISP od programatora do procka
wtedy może uda ci się pomóc
PostNapisane: 17 lut 2017, o 16:32
Dołączył(a): 10 lip 2015
Te czasy przy parametrze -B375 są bynajmniej dziwne. Obstawiam na 99% problem z PCB/połączeniami na stykówce. Pokaż schemat, zdjęcia płytki/połączeń.
PostNapisane: 17 lut 2017, o 16:37
Być może źle się wyraziłem bo nie miałem na razie doczynienia z zablokowanym procesorem i myślałem że to to: W każdym razie na tych procesorach nie jestem wstanie zmienić taktowania np za pomocą MkvCalkulatora zaznaczając np w fusach uproszczonych taktowanie 1 Mhz i dokonując w zakładce programator opcji zapis i ptaszek przy fusbitach na końcu klawisz wykonaj jak i tez w ten sam sposób zrestartować go do ostawień fabrycznych. Zawsze po wykonanej takiej operacji i kliknięciu ponownym sprawdź podłączony AVR atemga dalej ma taktowanie 8 Mhz. Również najprostszy program napisany w eclipsie do migania diodą wgrany do tego procesora skutkuje tylko jej świeceniem lub nie świeceniem wcale. Zaraz dodam zdjęcia.
ObrazekObrazekObrazek
PostNapisane: 17 lut 2017, o 16:49
No to skoro ci wygrywa procka w MkAvrCalculatorze to jak możesz mówić , że zablokowany procek ? Przecież to nonsens zupełny ;)
Oj panie panie - oglądaj że poradniki moje , zaglądaj na bloga - czy chociażby na stronę http://www.atnel.pl - oglądaj chociaż - przynajmniej te PODSTAWOWE ... bo inaczej to będziesz procki wyrzucał do kosza i to dobre procki ;)
może od tego zacznij:
http://mirekk36.blogspot.com/2013/06/gd ... ipsem.html
poza tym zajrzy tu:
http://atnel.pl/mkavrcalculator.html
masz tu PODSTAWOWĄ instrukcję ....
eeeeh - toż ten klawisz TYLKO i WYŁĄCZNIE ustawia fabryczne fusebity w MKAVRCALULATORZE a nie w procesorze. Żeby ci fabryczne się przywróciły to trzeba jeszcze je wprogramować do procka - ZIELONYM klawiszem w zakładce programator
ale to też NONSENS co chwilę sobie ustawiać do ustawień fabrycznych a potem co? od nowa taktowanie ?
po co ?
taktowanie możesz zmieniać w dowolnym momencie MkAvrCalculatorem ....
no ... tylko trzeba jak mówię przeczytać MINIMUM instrukcję ze strony ATNEL ?
A jeśli czegoś z tej instrukcji nie zrozumiesz - gdzieś się zatniesz to wtedy po to jest forum, żeby dopytać a ja chętnie podpowiem ....
Nie zaś tak, że ty wykonujesz jakieś swoje "czary-mary" na tzw "czuja" i wszystko źle robisz - bo po prostu na razie nie rozumiesz jak działa to programowanie procka
pomyśl też o tej książce
PostNapisane: 17 lut 2017, o 17:00
Dziękuje wszystkim za pomoc: Zmiana pinu z PB0 na PB1 w podstawowym programie ożywiła procesor. Z powrotem mogę zmieniać taktowania w mkvCalkulatorze jak i w Eclipsie ;)
Panie Mirku dziękuje za cierpliwość i wyrozumiałość ale nigdy po prostu mi sie jeszcze nie zdarzyło żebym nie mógł zmienić taktowania mikroprocesora jak i mieć taki błąd w eclpisie. Teraz się wszystko kompiluje i wgrywa aż miło.
PostNapisane: 17 lut 2017, o 17:12
zmiana pinu w programie w procku nie może ABSOLUTNIE w żaden sposób wpłynąć na możliwość bądź niemożliwość jego programowania - coś innego musiałeś mieć źle
ja obstawiam połączenia
PostNapisane: 17 lut 2017, o 17:55
Właśnie Panie Mirku to mnie dziwi, bo miałem ten problem na dwóch układach zarówno już zlutowanym jak i na płytce stykowej. Zaraz dodam zdjęcia by pokazać. Zaznaczam ze obydwa układy około 2 miesiące temu działały bez zarzutu. Później z braku czasu musiały leżeć i teraz z powrotem się za nie wziąłem. Od ładnych paru lat zajmuje się elektroniką a mikroprocesory to małymi kroczkami dzięki panu pomalutku się uczę bo bardzo mnie to interesuje. Niestety z braku czasu na blog jeszcze nie zaglądałem lecz filmiki jak zacz itp ogldałem na Youtobie i podziwiam pana wiedze. Dzięki nim i BlueBook-u udało się jakiś czas temu bezboleśnie wystartować, cieszyć się z pracy z układami mikroprocesorowymi.
Spróbuje z ciekawości jeszcze raz taką sytuacje wywołać tz. w grać program z tym parametrem czy znowu coś takiego nie będzie miało miejsca ;)
PostNapisane: 17 lut 2017, o 18:06
I tak nie widać połączeń. Sprawdzałeś układ na ewentualne zwarcia?
PostNapisane: 17 lut 2017, o 18:17
No i teraz okazuje się że mimo da wszystko zmieniać. Widocznie gdzieś jakiś zimny lut się objawia. Jeszce raz posprawdzam i polutuje wszystkie ścieżki ips. ;)
Układy zawsze sprawdzam po każdym lutowaniu czy nie ma jakiś zwarć w końcu nie chciałbym żeby się coś uszkodziło w dodatku np spalił procesor. Pozostaje kwesta zimnych lutów, połączeń. Obejrzę, poprawie wszystkie i mam nadzieje że problem nie powróci.
PostNapisane: 17 lut 2017, o 18:30
Dołączył(a): 14 lut 2014
A czym zasilasz ten układzik i co on robi?
Duży wyświetlacz, a nie widzę żadnego tranzystorka.
Kolega chyba nie załącza podświetlenia bezpośrednio z uC?
http://mirekk36.blogspot.com/2012/04/lcd-hd4478-jak-podaczac.html
Polecam zapoznać się ze schematem atb. Możesz ściągać od Mirka i masz pewność, że będzie działać.
http://atnel.pl/instrukcja-atb-rev-1-04.html
POZDROWIONKA
PostNapisane: 18 lut 2017, o 11:36
Zasilanie jest oczywiście zewnętrzne z zasilacza 12V na stabilizator. Typowa aplikacja układu Lm7805. Faktycznie nie uchwyciłem go na zdjęciu. W każdym razie na pierwszym zdjęciu widać kostkę do której jest podpinane jest napięcie 12V i zraz obok niej przewód AWG 3 żyłowy (zielono,żółto, brązowy) który prowadzi w dół zdjęcia do którego przylutowany jest stabilizator. ;)
