Teraz jest 5 sie 2026, o 21:49
PostNapisane: 20 lis 2014, o 17:14
Dołączył(a): 29 maja 2012
Witam. Tak jak w temacie ... chcę zaimplementować pewne biblioteki do AVR, lecz w konsoli otrzymuję :
16:56:22 **** Incremental Build of configuration Release for project LED_BLINK_CPdev ****
make all
Building file: ../LED_BLINK_AVR.c
Invoking: AVR Compiler
avr-gcc -Wall -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega128 -DF_CPU=14745600UL -MMD -MP -MF"LED_BLINK_AVR.d" -MT"LED_BLINK_AVR.d" -c -o "LED_BLINK_AVR.o" "../LED_BLINK_AVR.c"
Finished building: ../LED_BLINK_AVR.c
Building target: LED_BLINK_CPdev.elf
Invoking: AVR C Linker
avr-gcc -Wl,-Map,LED_BLINK_CPdev.map -mmcu=atmega128 -o "LED_BLINK_CPdev.elf"  ./VM/vm.o  ./LED_BLINK_AVR.o
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(fp_arccos.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/fp_arccos.S:76:(.text.avr-libc.fplib+0x24): relocation truncated to fit: R_AVR_13_PCREL against symbol `__subsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(fp_powsodd.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/fp_powsodd.S:59:(.text.avr-libc.fplib+0x10): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(fp_powsodd.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/fp_powsodd.S:69:(.text.avr-libc.fplib+0x20): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(inverse.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/inverse.S:50:(.text.avr-libc.fplib+0xc): relocation truncated to fit: R_AVR_13_PCREL against symbol `__divsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_div_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log10.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log10.S:47:(.text.avr-libc.fplib+0xa): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log.S:96:(.text.avr-libc.fplib+0x46): relocation truncated to fit: R_AVR_13_PCREL against symbol `__addsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log.S:100:(.text.avr-libc.fplib+0x4e): relocation truncated to fit: R_AVR_13_PCREL against symbol `__addsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log.S:116:(.text.avr-libc.fplib+0x6a): relocation truncated to fit: R_AVR_13_PCREL against symbol `__floatsisf' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_si_to_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(modf.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/modf.S:90:(.text.avr-libc.fplib+0x3e): relocation truncated to fit: R_AVR_13_PCREL against symbol `__subsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(square.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/square.S:43:(.text.avr-libc.fplib+0x4): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
collect2.exe: error: ld returned 1 exit status
make: *** [LED_BLINK_CPdev.elf] Błąd 1
16:56:23 Build Finished (took 1s.187ms)
PostNapisane: 20 lis 2014, o 20:05
Dołączył(a): 22 cze 2013
Moja szklana kula podpowiada mi, że są jakieś błędy w kodzie bibliotek
PostNapisane: 20 lis 2014, o 20:24
W atmel studio przechodzi.
Dostałem wskazówkę, że trzeba załączyć plik libm.a do linkera. Gdzie dorwać ten plik?
PostNapisane: 20 lis 2014, o 20:46
Może zostań przy AS. Co prawda na tym forum eclipse jest jedyne słuszne ale jak widać AS czasami (ufff) jest lepsze :)
PostNapisane: 20 lis 2014, o 20:48
Nie chce Atmel Studio, nie lubię w tym pracować, z resztą mój laptop również :/
PostNapisane: 20 lis 2014, o 20:51
Rozumiem Twój ból. To samo mam z eclipse :)
A plik jest w Toolchainie. W przypadku AS jest ich kilka w zależności od architektury komputera. Siedzą m.in. tu --> C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\ARMGCC
PostNapisane: 20 lis 2014, o 21:16
Może kolega podrzucić, bo będę zmuszony do instalacji?
PostNapisane: 20 lis 2014, o 21:27
Dołączył(a): 20 wrz 2013
Nie "podrzucić", biblioteka powinna być w toolchain a instaluje się ją mniej więcej tak: http://mirekk36.blogspot.com/2012/09/eclipse-avr-gcc-doaczanie-bibliotek-a.html. Ponieważ to lib systemowy to interesuje cię tylko ostatni obrazek, ustawiania ścieżek pomijasz.
PostNapisane: 20 lis 2014, o 21:50
Kompilacja poszła.
W Atmel Studio miałem 65kB FLASH.
W Eclipse jest 40kB FLASH i program nie działa.
Czy opcja "Exclude from Build" jest równoważna z opcją "No Compile" w AVR studio?
PostNapisane: 20 lis 2014, o 21:56
Ahhh.. Zostałem uprzedzony :(
PostNapisane: 21 lis 2014, o 00:11
Dołączył(a): 03 mar 2014
Kolega WoodPaker pora przejść na AS 6.2 ;)
Do autora tematu:
W AS 6.2 Toolchain instaluje się z automatu.
Co do wielkości kodu, to nie wiem jak kolega ma ustawioną optymalizację kompilacji w AS. Niech kolega ustawi na -Os (for size) i wtedy zobaczy jak wielki będzie hex.
Jak kolega nie lubi programować w AS to trzeba spróbować Eclipse,
z Niebieskim pozdRowieniem,
Doman89
PostNapisane: 21 lis 2014, o 08:11
Ależ mam 6.2. Ścieżka dostępu była przykładowa :lol:
PostNapisane: 21 lis 2014, o 09:32
Chodzi o to, że Eclipse coś źle kompiluje, program niby działa ale nie tak jak trzeba. To samo w AS działało dobrze.
Po prostu coś nie tak jest z kompilacją Eclipsa, chyba za bardzo to optymalizuje. Konsula ECLIPSE po zbudowaniu:
09:31:34 **** Incremental Build of configuration Release for project LED_BLINK_CPdev ****
make all
avr-gcc -Wl,-Map,LED_BLINK_CPdev.map -mmcu=atmega128 -o "LED_BLINK_CPdev.elf"  ./VM/vm.o  ./LCD/lcd44780.o  ./LED_BLINK_AVR.o   -lm
Finished building target: LED_BLINK_CPdev.elf
Invoking: AVR Create Extended Listing
avr-objdump -h -S LED_BLINK_CPdev.elf  >"LED_BLINK_CPdev.lss"
Finished building: LED_BLINK_CPdev.lss
Create Flash image (ihex format)
avr-objcopy -R .eeprom -R .fuse -R .lock -R .signature -O ihex LED_BLINK_CPdev.elf  "LED_BLINK_CPdev.hex"
Finished building: LED_BLINK_CPdev.hex
Create eeprom image (ihex format)
avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex LED_BLINK_CPdev.elf  "LED_BLINK_CPdev.eep"
Finished building: LED_BLINK_CPdev.eep
Invoking: Print Size
avr-size --format=avr --mcu=atmega128 LED_BLINK_CPdev.elf
AVR Memory Usage
Device: atmega128
Program:   40164 bytes (30.6% Full)
(.text + .data + .bootloader)
Data:       1107 bytes (27.0% Full)
(.data + .bss + .noinit)
Finished building: sizedummy
09:31:37 Build Finished (took 2s.937ms)
Użytkownicy przeglądający ten dział: Bing [Bot] i 1 gość
