Teraz jest 6 kwi 2026, o 17:43
PostNapisane: 15 lis 2014, o 18:06
Dołączył(a): 29 maja 2012
Witam. Buduję pewien projekt z niepowodzeniem otrzymuję w konsoli :
**** Build of configuration Release for project VM_TEST ****
make all
Building file: ../main.c
Invoking: AVR Compiler
avr-gcc -Wall -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega128 -DF_CPU=14745600UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c"
Finished building: ../main.c
Building target: VM_TEST.elf
Invoking: AVR C Linker
avr-gcc -Wl,-Map,VM_TEST.map -mmcu=atmega128 -o "VM_TEST.elf"  ./VM/vm.o  ./io.o ./main.o
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(fp_arccos.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/fp_arccos.S:76:(.text.avr-libc.fplib+0x24): relocation truncated to fit: R_AVR_13_PCREL against symbol `__subsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(fp_powsodd.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/fp_powsodd.S:59:(.text.avr-libc.fplib+0x10): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(fp_powsodd.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/fp_powsodd.S:69:(.text.avr-libc.fplib+0x20): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(inverse.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/inverse.S:50:(.text.avr-libc.fplib+0xc): relocation truncated to fit: R_AVR_13_PCREL against symbol `__divsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_div_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log10.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log10.S:47:(.text.avr-libc.fplib+0xa): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log.S:96:(.text.avr-libc.fplib+0x46): relocation truncated to fit: R_AVR_13_PCREL against symbol `__addsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(log.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/log.S:100:(.text.avr-libc.fplib+0x4e): relocation truncated to fit: R_AVR_13_PCREL against symbol `__addsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(modf.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/modf.S:90:(.text.avr-libc.fplib+0x3e): relocation truncated to fit: R_AVR_13_PCREL against symbol `__subsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_addsub_sf.o)
c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/../../../../avr/lib/avr51\libc.a(square.o):/data2/home/toolsbuild/jenkins-knuth/workspace/avr8-gnu-toolchain/src/avr-libc/libm/fplib/square.S:43:(.text.avr-libc.fplib+0x4): relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsf3' defined in .text section in c:/program files (x86)/atmel/avr tools/avr toolchain/bin/../lib/gcc/avr/4.7.2/avr51\libgcc.a(_mul_sf.o)
collect2.exe: error: ld returned 1 exit status
make: *** [VM_TEST.elf] Błąd 1
**** Build Finished ****
Dostałem podpowiedź, że muszę dołączyć do linkowania bibliotęke libm.a. Szukam w sieci i nie znalazłem. Czy ona jest gdzieś na dysku? Korzystam z eclipse + atmel toolchain. Jak to zrobić?
PostNapisane: 15 lis 2014, o 18:29
Dołączył(a): 12 maja 2013
Wrzuć toolchaina do głównego katalogu na dysku C. Nie używaj spacji w nazwach katalogów.
Zamiast:
zainstaluj go w:
C:/toolchain
Und schreien
Spring
Erlöse mich
Spring
PostNapisane: 15 lis 2014, o 18:39
Znalazłem rozwiązanie na blogu mirka......
P.S tam już chyba jest wszystko :D
