Teraz jest 14 wrz 2026, o 15:56
PostNapisane: 22 sty 2014, o 19:44
Dołączył(a): 23 paź 2011
org.eclipse.core.runtime.CoreException: The file does not exist.
   at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.create(ResourceFileBuffer.java:237)
   at org.eclipse.core.internal.filebuffers.TextFileBufferManager.connect(TextFileBufferManager.java:112)
   at org.eclipse.ui.editors.text.TextFileDocumentProvider.createFileInfo(TextFileDocumentProvider.java:559)
   at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.createFileInfo(CDocumentProvider.java:786)
   at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect(TextFileDocumentProvider.java:478)
   at org.eclipse.cdt.internal.ui.editor.CDocumentProvider.connect(CDocumentProvider.java:718)
   at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4225)
   at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:237)
   at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1480)
   at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:169)
   at org.eclipse.cdt.internal.ui.editor.CEditor.internalDoSetInput(CEditor.java:1508)
   at org.eclipse.cdt.internal.ui.editor.CEditor.doSetInput(CEditor.java:1471)
   at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3212)
   at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:1753)
   at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3230)
   at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3257)
   at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:359)
   at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:306)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
   at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
   at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
   at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
   at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
   at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
   at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
   at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
   at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
   at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
   at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
   at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
   at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
   at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
   at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
   at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
   at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
   at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
   at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
   at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
   at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
   at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
   at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
   at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
   at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
   at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Wersja Kepler od Sun'a. Wcześniej miałem to samo po upgrade z JUNO na INDYGO.
Co ciekawe jak odpalam z DVD od BB INDYGO to tego nie ma...
Czekamy na RedBook'a!
PostNapisane: 22 sty 2014, o 19:48
JAva java java
brak scieżki w zmienne patch
w ustawieniach zaawansowanych dodać do systemowej PATH wpis ;C:\Program Files (x86)\Java\jre7 na końcu tego co tam jest
ew skopiowć do folderu eclipse folder JRE z javy
PostNapisane: 22 sty 2014, o 20:00
Hmm... to nie Java.
Ale toolchain nie zainstalowany jeszcze - może to to ;)
PostNapisane: 22 sty 2014, o 20:22
juz wiemy że to psoci Workspace :)
